need help
Regina Obe
lr at pcorp.us
Thu Apr 4 15:37:37 PDT 2024
I'd check to make sure hibernate has usage rights and execute for all
functions.
I recall they changed that in PG 15 I think it was.
Sent: Wednesday, April 3, 2024 4:52 AM
To: postgis-users at lists.osgeo.org
Subject: need help
Hello again I updated postgis from 3.0 to 3.3 but didn't execute "alter
extension postgis UPDATE;" and restart db. The query was working well but
after update it starts throwing errors below.
ERROR: type "geometry" does not exist at character 98
QUERY: SELECT
ST_FlipCoordinates(st_setsrid(st_geogfromtext(replace(new.tesiskoordinat,','
,'.')),4326)::geometry)
it is a simple insert into sql, it throws only when inserted via hibernate,
postgis installed in public schema and
user has search_path= public, another_schema
table has select priviliges on public.spatial_ref_sys
when I check installed extention with \dx the output
postgis | 3.0.4 | public | PostGIS geometry, geography,
and raster spatial types and functions
but when run select Postgis_Version();
3.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240404/99843030/attachment.htm>
