Importing tiles with raster2pgsql
Andreas B
panden at gmail.com
Fri Dec 13 03:48:17 PST 2024
Regina,
I'm linking to a folder with a zip containing a subset of tiles that
demonstrates my problem, a script to run the commands, and two screenshots.
Note that I'm a PostGIS beginner, so it's possible I'm doing something
wrong!
The issues encountered differs a bit from what I described yesterday, but
the essence is the same.
Link to folder:
https://www.dropbox.com/scl/fo/bk8cwktahry0oj0ab2rsz/AHdTD73unb4Efxtgf7exfm0?rlkey=esjtw2iyzysan2hdqklwmj5e3&st=hupv5tsr&dl=0
Best,
Andreas
On Thu, Dec 12, 2024 at 3:26 PM Regina Obe <lr at pcorp.us> wrote:
> Andreas,
> Yes I would expect them to give the same result.
> What version of raster2pgsql are you running? It should tell you if you
> run raster2pgsql without any args.
> Also what platform are you on? Any chance you have some of those tiles
> available so we can check it out?
> *From:* Andreas B <panden at gmail.com>
> *Sent:* Thursday, December 12, 2024 6:17 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Importing tiles with raster2pgsql
> Hi all,
> I have a dataset with several hundred tiles (GeoTIFFs) that make up a
> digital terrain model.
> Each tile is 0.5d x 0.5d.
> I tried to load these GeoTIFFs to PostGIS with:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 tif/*.tif (1)
> The data was loaded, but when viewing in QGIS, it looked like jagged lines
> with areas of white overlain by pieces of neighboring tiles, etc.
> This didn't look right.
> I also noticed that for each tif, the constraints were printed.
> I expected this to be done once, after the last tile was loaded.
> I then created a virtual raster with gdalbuildvrt:
> $ gdalbuildvrt merge.vrt tif/*.tif (2)
> And then used raster2pgsql to load in the vrt:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 merge.vrt |
> psql (3)
> The data was loaded, and looked good in QGIS.
> Shouldn't commands (1) and (3) give the same results, or am I
> misunderstanding?
> Best, Andreas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241213/a2c57e4e/attachment.htm>
