Importing tiles with raster2pgsql
Andreas B panden at gmail.com
Thu Dec 12 07:11:53 PST 2024
Regina,
I'm using Debian 12 (bookworm).
PostgreSQL and PostGIS installed with apt:
# SELECT version();
                                                       version
 PostgreSQL 15.10 (Debian 15.10-0+deb12u1) on x86_64-pc-linux-gnu, compiled
by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
(1 row)
# SELECT PostGIS_full_version();
postgis_full_version
 POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.11.1-CAPI-1.17.1"
PROJ="9.1.1" LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1"
WAGYU="0.5.0 (Internal)"
(1 row)
raster2pgsql version:
$ raster2pgsql
RELEASE: 3.3.2 GDAL_VERSION=36 (4975da8)
The tiles are available; I'll try my workflow again, document, and share
the tiles.
Thanks!
Best,
Andreas
On Thu, Dec 12, 2024 at 3:26 PM Regina Obe <lr at pcorp.us> wrote:
> Andreas,
> Yes I would expect them to give the same result.
> What version of raster2pgsql are you running?  It should tell you if you
> run raster2pgsql without any args.
> Also what platform are you on?  Any chance you have some of those tiles
> available so we can check it out?
> *From:* Andreas B <panden at gmail.com>
> *Sent:* Thursday, December 12, 2024 6:17 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Importing tiles with raster2pgsql
> Hi all,
> I have a dataset with several hundred tiles (GeoTIFFs) that make up a
> digital terrain model.
> Each tile is 0.5d x 0.5d.
> I tried to load these GeoTIFFs to PostGIS with:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 tif/*.tif (1)
> The data was loaded, but when viewing in QGIS, it looked like jagged lines
> with areas of white overlain by pieces of neighboring tiles, etc.
> This didn't look right.
> I also noticed that for each tif, the constraints were printed.
> I expected this to be done once, after the last tile was loaded.
> I then created a virtual raster with gdalbuildvrt:
> $ gdalbuildvrt merge.vrt tif/*.tif (2)
> And then used raster2pgsql to load in the vrt:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 merge.vrt |
> psql (3)
> The data was loaded, and looked good in QGIS.
> Shouldn't commands (1) and (3) give the same results, or am I
> misunderstanding?
> Best, Andreas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241212/0774c88f/attachment.htm>
