Importing tiles with raster2pgsql
Andreas B panden at gmail.com
Mon Dec 16 04:49:40 PST 2024
No worries.
I compiled a recent version of raster2pgsql just to check, but got the same
issue:
$ raster2pgsql
RELEASE: 3.5.0 GDAL_VERSION=36 (d2c3ca4)
Just to reiterate:
When using raster2pgsql I get 'WARNING'..:
WARNING: Raster with different alignment found in the set of rasters being
converted to PostGIS raster
and 'NOTICE' after the ANALYZE is run:
NOTICE:  Adding SRID constraint
NOTICE:  Adding scale-X constraint
NOTICE:  Adding scale-Y constraint
NOTICE:  Adding blocksize-X constraint
NOTICE:  Adding blocksize-Y constraint
NOTICE:  Adding alignment constraint
NOTICE:  The rasters (pixel corner coordinates) are not aligned
NOTICE:  Unable to add constraint: enforce_same_alignment_rast
NOTICE:  SQL used for failed constraint: ALTER TABLE
public.merge_raster2pgsql ADD CONSTRAINT enforce_same_alignment_rast CHECK
(st_samealignment(rast,
'0100000000000000000000494000000000000049C00000000050B3FCC0000000C02246584100000000000000000000000000000000E964000001000100'::raster))
NOTICE:  Returned error message: check constraint
"enforce_same_alignment_rast" of relation "merge_raster2pgsql" is violated
by some row (23514)
WARNING:  Unable to add constraint: 'same_alignment'.  Skipping
NOTICE:  Adding number of bands constraint
NOTICE:  Adding pixel type constraint
NOTICE:  Adding nodata value constraint
NOTICE:  Adding out-of-database constraint
NOTICE:  Adding maximum extent constraint
This does not occur when I make a virtual raster (vrt) with gdalbuildvrt,
and use that as input to raster2pgsql; no warning or notices, and the data
looks good in QGIS.
Best,
Andreas
On Sun, Dec 15, 2024 at 12:35 AM Regina Obe <lr at pcorp.us> wrote:
> Sorry haven’t had a chance to look thru this yet.  Going to be tied up for
> the next two weeks so I might not get a chance until much later.
> If any others are interested in investigating, please don’t wait for me.
> Thanks,
> Regina
> *From:* Andreas B <panden at gmail.com>
> *Sent:* Friday, December 13, 2024 6:48 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: Importing tiles with raster2pgsql
> Regina,
> I'm linking to a folder with a zip containing a subset of tiles that
> demonstrates my problem, a script to run the commands, and two screenshots.
> Note that I'm a PostGIS beginner, so it's possible I'm doing something
> wrong!
> The issues encountered differs a bit from what I described yesterday, but
> the essence is the same.
> Link to folder:
> https://www.dropbox.com/scl/fo/bk8cwktahry0oj0ab2rsz/AHdTD73unb4Efxtgf7exfm0?rlkey=esjtw2iyzysan2hdqklwmj5e3&st=hupv5tsr&dl=0
> Best,
> Andreas
> On Thu, Dec 12, 2024 at 3:26 PM Regina Obe <lr at pcorp.us> wrote:
> Andreas,
> Yes I would expect them to give the same result.
> What version of raster2pgsql are you running?  It should tell you if you
> run raster2pgsql without any args.
> Also what platform are you on?  Any chance you have some of those tiles
> available so we can check it out?
> *Sent:* Thursday, December 12, 2024 6:17 AM
> *Subject:* Importing tiles with raster2pgsql
> Hi all,
> I have a dataset with several hundred tiles (GeoTIFFs) that make up a
> digital terrain model.
> Each tile is 0.5d x 0.5d.
> I tried to load these GeoTIFFs to PostGIS with:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 tif/*.tif (1)
> The data was loaded, but when viewing in QGIS, it looked like jagged lines
> with areas of white overlain by pieces of neighboring tiles, etc.
> This didn't look right.
> I also noticed that for each tif, the constraints were printed.
> I expected this to be done once, after the last tile was loaded.
> I then created a virtual raster with gdalbuildvrt:
> $ gdalbuildvrt merge.vrt tif/*.tif (2)
> And then used raster2pgsql to load in the vrt:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 merge.vrt |
> psql (3)
> The data was loaded, and looked good in QGIS.
> Shouldn't commands (1) and (3) give the same results, or am I
> misunderstanding?
> Best, Andreas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241216/60eff6a0/attachment.htm>
