Importing tiles with raster2pgsql
Andreas B
panden at gmail.com
Thu Dec 19 01:09:41 PST 2024
I checked the extent of the tiles, and 'NHS-D0309_50M_E25833.tif' has a
different extent that is incompatible with the other tiles.
All the other tifs are lined up with coordinates ending in 00, 25, 50 and
75; 'NHS-D0309_50M_E25833.tif' does not.
This explains the not aligned-stuff, and if I remove that tile, no
misalignment notices are given.
This does not solve my problem regarding the data looking strange in QGIS,
unfortunately. I still get an image like the one in merge_raster2pgsql.png.
I also tried with a (more) recent version of PostgreSQL/PostGIS and
raster2pgsql, but the issue is still there:
# SELECT version();
PostgreSQL 16.3 [..]
# SELECT PostGIS_full_version();
POSTGIS="3.4.2 POSTGIS_REVISION" [EXTENSION] (liblwgeom version mismatch:
"3.4.2 c19ce56") PGSQL="160" GEOS="3.13.0-CAPI-1.19.0" (compiled against
GEOS 3.12.2) PROJ="9.5.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgres/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.10.0, r
eleased 2024/11/01" LIBXML="2.13.5" LIBJSON="0.18" LIBPROTOBUF="1.5.0"
WAGYU="0.5.0 (Internal)" (core procs from "3.4.2 c19ce56" need upgrade)
RASTER (raster procs from "3.4
$ raster2pgsql
RELEASE: 3.4.2 GDAL_VERSION=310 (POSTGIS_REVISION)
Another observation is that the choice of tile size varies (I'm using -t
auto):
With vrt as input, always uses 128x128:
INFO: Using computed tile size: 128x128
With *.tif as input the tile size varies depending on which tile is
processed first, e.g.:
INFO: Using computed tile size: 215x274
or
INFO: Using computed tile size: 97x46
or
INFO: Using computed tile size: 18x10
Just testing and thinking out loud!
Best,
Andreas
On Sun, Dec 15, 2024 at 12:35 AM Regina Obe <lr at pcorp.us> wrote:
> Sorry haven’t had a chance to look thru this yet. Going to be tied up for
> the next two weeks so I might not get a chance until much later.
> If any others are interested in investigating, please don’t wait for me.
> Thanks,
> Regina
> *From:* Andreas B <panden at gmail.com>
> *Sent:* Friday, December 13, 2024 6:48 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: Importing tiles with raster2pgsql
> Regina,
> I'm linking to a folder with a zip containing a subset of tiles that
> demonstrates my problem, a script to run the commands, and two screenshots.
> Note that I'm a PostGIS beginner, so it's possible I'm doing something
> wrong!
> The issues encountered differs a bit from what I described yesterday, but
> the essence is the same.
> Link to folder:
> https://www.dropbox.com/scl/fo/bk8cwktahry0oj0ab2rsz/AHdTD73unb4Efxtgf7exfm0?rlkey=esjtw2iyzysan2hdqklwmj5e3&st=hupv5tsr&dl=0
> Best,
> Andreas
> On Thu, Dec 12, 2024 at 3:26 PM Regina Obe <lr at pcorp.us> wrote:
> Andreas,
> Yes I would expect them to give the same result.
> What version of raster2pgsql are you running? It should tell you if you
> run raster2pgsql without any args.
> Also what platform are you on? Any chance you have some of those tiles
> available so we can check it out?
> *Sent:* Thursday, December 12, 2024 6:17 AM
> *Subject:* Importing tiles with raster2pgsql
> Hi all,
> I have a dataset with several hundred tiles (GeoTIFFs) that make up a
> digital terrain model.
> Each tile is 0.5d x 0.5d.
> I tried to load these GeoTIFFs to PostGIS with:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 tif/*.tif (1)
> The data was loaded, but when viewing in QGIS, it looked like jagged lines
> with areas of white overlain by pieces of neighboring tiles, etc.
> This didn't look right.
> I also noticed that for each tif, the constraints were printed.
> I expected this to be done once, after the last tile was loaded.
> I then created a virtual raster with gdalbuildvrt:
> $ gdalbuildvrt merge.vrt tif/*.tif (2)
> And then used raster2pgsql to load in the vrt:
> $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 merge.vrt |
> psql (3)
> The data was loaded, and looked good in QGIS.
> Shouldn't commands (1) and (3) give the same results, or am I
> misunderstanding?
> Best, Andreas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241219/dec8b411/attachment.htm>
