ST_Union behaviour
Regina Obe
lr at pcorp.us
Mon Dec 23 01:46:16 PST 2024
Are you unioning one geometry or many?
The only reason I can think of why ST_Union would return unchanged overlapping polygons is if you fed it a geometry collection or invalid multipolygon with overlapping polygons.
In these cases you should be using ST_UnaryUnion https://postgis.net/docs/ST_UnaryUnion.html
Sent: Monday, December 23, 2024 3:47 AM
To: postgis-users at lists.osgeo.org
Subject: ST_Union behaviour
Does someone know why ST_Union behaves differently with linestrings and polygons?
If a table contains linestrings that overlap at some points then ST_Union creates a collection of linestrings that are splitted at intersections.
If a table contains polygons with overlaps then ST_Union creates a collection of polygons that are still overlapped and are not splitted (the result contains only the original polygons).
Thanks in advance.
Antonio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241223/69bdd30f/attachment.htm>
