ST_Union behaviour
Regina Obe lr at pcorp.us
Mon Dec 23 14:52:40 PST 2024
Best to keep conversation on the list.  Added back postgis-users.
I think what might do what you want here is combination of ST_Boundary, ST_Union, and ST_Polygonize
1.	Get the linework of the polygons using ST_Boundary –  https://postgis.net/docs/ST_Boundary.html
2.	Union the linework – as you noted ST_Union when fed linestrings will create a multilinestring with splits at the junctions https://postgis.net/docs/ST_Union.html
3.	Then polygonise the linework -  https://postgis.net/docs/ST_Polygonize.html  (this is an aggregate that returns a geometry collection of all the polygons formed from the linework
4.	Use ST_Dump to dump out the individual polygons from the polygonize operation  https://postgis.net/docs/ST_Dump.html
WITH a(name, geom) AS ( VALUES ( 'A', ST_GeomFromText('POLYGON((0 0, 0 4, 4 4, 4 0, 0 0))') )
      , ( 'B', ST_GeomFromText('POLYGON((3 1, 3 3, 6 3, 6 1, 3 1))') )
      , ( 'C', ST_GeomFromText('POLYGON((3 -1, 3 2, 8 2, 8 -1, 3 -1))') )
, b(geom) AS (SELECT ST_Union(ST_Boundary(a.geom)) AS geom FROM a)
SELECT (ST_Dump(ST_Polygonize( b.geom) )).geom
FROM b;
Sent: Monday, December 23, 2024 6:37 AM
To: Regina Obe <lr at pcorp.us>
Subject: Re: ST_Union behaviour
Regina, thanks for the fast reply.
I am unioning 4 distinct polygons(see attached polygon_overlapping.jpeg) which present some overlapping (some areas with 2 overlapping polygons, 1 area with 3 overlapping polygons) and I would like to create a new table comprising all these polygons but splitted where they overlap. (see attached new_polygons.jpeg)
The four initial polygons are all valid as you can see from the results of the following query
SELECT
  id,
  ST_isValid(geom)
FROM chp02.prova_overlap;
-- 4 rows
"id" "st_isvalid"
1 true
2 true
3 true
4 true
I have also tried, as you suggested, the ST_UnaryUnion but the result is the same as ST_Union.
Antonio
Il giorno lun 23 dic 2024 alle ore 10:46 Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > ha scritto:
Are you unioning one geometry or many?
The only reason I can think of why ST_Union would return unchanged overlapping polygons is if you fed it a geometry collection or invalid multipolygon with overlapping polygons.
In these cases you should be using ST_UnaryUnion  https://postgis.net/docs/ST_UnaryUnion.html
From: Antonio Valanzano <anvalanz at gmail.com <mailto:anvalanz at gmail.com> >
Sent: Monday, December 23, 2024 3:47 AM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: ST_Union behaviour
Does someone know why ST_Union behaves differently with linestrings and polygons?
If a table contains linestrings that overlap at some points then ST_Union creates a collection of linestrings  that are splitted at intersections.
If a table contains polygons with overlaps then ST_Union creates a collection of polygons that are still overlapped and are not splitted (the result contains only the original polygons).
Thanks in advance.
Antonio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241223/a1717d5e/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241223/a1717d5e/attachment.jpeg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241223/a1717d5e/attachment-0001.jpeg>
