Update topology 3.3.3 to 3.3.6 fails
kaido vaikla
kaido.vaikla at gmail.com
Tue Dec 24 02:50:30 PST 2024
Regina,
in my first post you see:
teglms=# show search_path ;
search_path
postgis, topology
(1 row)
br
Kaido
On Tue, 24 Dec 2024 at 03:06, Regina Obe <lr at pcorp.us> wrote:
> I vaguely recall running into this issue when doing CREATE EXTENSION
> postgis_topology; But haven’t seen the issue in recent versions of postgis
> (e.g. 3.4 and above) and can’t remember how I worked around it.
> Is your search_path set just for your user setting or for the database?
> Have you tried resetting the search path.
> Something like:
> set search_path=postgis, topology;
> alter extension postgis_topology update to "3.3.6";
> Are you able to use a newer PostGIS say 3.3.7 (3.3.8 came out yesterday so
> might not be available yet in most distros),
> *From:* kaido vaikla <kaido.vaikla at gmail.com>
> *Sent:* Monday, December 23, 2024 6:15 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Update topology 3.3.3 to 3.3.6 fails
> Hi,
> Need some help.
> teglms=# \dx post*
> List of installed extensions
> Name | Version | Schema | Description
> postgis | 3.3.6 | postgis | PostGIS geometry and geography
> spatial types and functions
> postgis_raster | 3.3.6 | postgis | PostGIS raster types and functions
> postgis_topology | 3.3.3 | topology | PostGIS topology spatial types
> and functions
> (3 rows)
> teglms=# alter extension postgis_topology update to "3.3.6";
> ERROR: type "geometry" does not exist
> teglms=# \dT+ geometry
> List of data types
> Schema | Name | Internal name | Size | Elements | Owner |
> Access privileges | Description
> postgis | geometry | geometry | var | | eglmsadmin |
> | postgis type: The type representing spatial features with
> planar coordinate systems.
> (1 row)
> teglms=# select user;
> user
> eglmsadmin
> (1 row)
> search_path
> postgis, topology
> (1 row)
> Why update can't find a type geometry?
> br
> Kaido
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241224/96b948f7/attachment.htm>
