Update topology 3.3.3 to 3.3.6 fails
Regina Obe lr at pcorp.us
Tue Dec 24 06:54:17 PST 2024
Yah that part I read.  I was just thinking that maybe during the ALTER EXTENSION process it ignores whatever search_path the user has, but might not ignore the session search_path.
If you do show search_path, it’s what the search_path is for YOU, but not necessarily what will be in effect when ALTER EXTENSION runs.
So that is why I was asking you to reset it for the session.
That said I forget if the search_path is also reset during ALTER EXTENSION so that may not work anyway.
Sent: Tuesday, December 24, 2024 5:51 AM
To: Regina Obe <lr at pcorp.us>
Cc: postgis-users at lists.osgeo.org
Subject: Re: Update topology 3.3.3 to 3.3.6 fails
Regina,
in my first post you see:
teglms=# show search_path ;
    search_path
 postgis, topology
(1 row)
br
Kaido
On Tue, 24 Dec 2024 at 03:06, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I vaguely recall running into this issue when doing CREATE EXTENSION postgis_topology;  But haven’t seen the issue in recent versions of postgis (e.g. 3.4 and above) and can’t remember how I worked around it.
Is your search_path set just for your user setting or for the database?
Have you tried resetting the search path.
Something like:
set search_path=postgis, topology;
alter extension postgis_topology update to "3.3.6";
Are you able to use a newer PostGIS say 3.3.7 (3.3.8 came out yesterday so might not be available yet in most distros),
From: kaido vaikla <kaido.vaikla at gmail.com <mailto:kaido.vaikla at gmail.com> >
Sent: Monday, December 23, 2024 6:15 AM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: Update topology 3.3.3 to 3.3.6 fails
Need some help.
teglms=# \dx post*
                                    List of installed extensions
       Name       | Version |  Schema  |                        Description
 postgis          | 3.3.6   | postgis  | PostGIS geometry and geography spatial types and functions
 postgis_raster   | 3.3.6   | postgis  | PostGIS raster types and functions
 postgis_topology | 3.3.3   | topology | PostGIS topology spatial types and functions
(3 rows)
teglms=# alter extension postgis_topology update to  "3.3.6";
ERROR:  type "geometry" does not exist
teglms=# \dT+ geometry
        List of data types
 Schema  |   Name   | Internal name | Size | Elements |   Owner    | Access privileges |                                     Description
 postgis | geometry | geometry      | var  |          | eglmsadmin |                   | postgis type: The type representing spatial features with planar coordinate systems.
(1 row)
teglms=# select user;
    user
 eglmsadmin
(1 row)
    search_path
 postgis, topology
(1 row)
Why update can't find a type geometry?
br
Kaido
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241224/c1b061da/attachment.htm>
