ST_Union behaviour
Martin Davis
mtnclimb at gmail.com
Tue Dec 24 09:34:29 PST 2024
There's also the technique described here:
https://gis.stackexchange.com/a/437341/14766
On Tue, Dec 24, 2024 at 9:32 AM Martin Davis <mtnclimb at gmail.com> wrote:
> The behaviour of ST_Union with polygons follows the mathematical concept
> of union in point-set topology. It produces as few polygons as possible
> which contain all the points of the input polygons.
> For LineStrings, they obviously can't "fork", so they are cut at
> intersections. And actually ST_Union goes a bit further and cuts the
> linework at every node point. This was a design decision from way back.
> It avoids the cost of merging contiguous lines (which can be done post
> facto with ST_LineMerge).
> What you want is often called "overlay". Currently the best way to do it
> is via the technique described in Paul's blog post, or via PostGIS Topology
> (which might be more scalable but slower).
> On Mon, Dec 23, 2024 at 9:56 AM Regina Obe <lr at pcorp.us> wrote:
>> Are you unioning one geometry or many?
>> The only reason I can think of why ST_Union would return unchanged
>> overlapping polygons is if you fed it a geometry collection or invalid
>> multipolygon with overlapping polygons.
>> In these cases you should be using ST_UnaryUnion
>> https://postgis.net/docs/ST_UnaryUnion.html
>> *From:* Antonio Valanzano <anvalanz at gmail.com>
>> *Sent:* Monday, December 23, 2024 3:47 AM
>> *To:* postgis-users at lists.osgeo.org
>> *Subject:* ST_Union behaviour
>> Does someone know why ST_Union behaves differently with linestrings and
>> polygons?
>> If a table contains linestrings that overlap at some points then ST_Union
>> creates a collection of linestrings that are splitted at intersections.
>> If a table contains polygons with overlaps then ST_Union creates a
>> collection of polygons that are still overlapped and are not splitted (the
>> result contains only the original polygons).
>> Thanks in advance.
>> Antonio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241224/7863a924/attachment.htm>
