Current postgis builds broken???
Scott Pasnikowski
spasnikowski at semantic-ai.com
Fri Jan 12 11:24:19 PST 2024
Yesterday I was doing a fresh install of our server package and quickly recieved error messages that postgis wont install...
This appears to have happened late afternoon (PST).
Does anyone know whats up?
[rocky at sai-int-test-cortex-airflow-test4 singlenode]$ sudo dnf -y install postgis34_15
Last metadata expiration check: 0:02:48 ago on Fri 12 Jan 2024 07:15:57 PM UTC.
Error:
Problem: package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires gdal36-libs >= 3.6.3, but none of the providers can be installed
- package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires libgdal.so.32()(64bit), but none of the providers can be installed
- cannot install the best candidate for the job
- nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-4PGDG.rhel8.x86_64 from pgdg-common
- nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-5PGDG.rhel8.x86_64 from pgdg-common
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240112/da74a45c/attachment.htm>
