Current postgis builds broken???
Regina Obe
lr at pcorp.us
Fri Jan 12 12:03:53 PST 2024
Looks like you might be missing epel-release
Did you already do
dnf -y install epel-release
as detailed here -
https://postgis.net/documentation/getting_started/install_red_hat/
You might get more answers on the
https://www.postgresql.org/list/pgsql-pkg-yum/ mailing list.
Hope that helps,
Regina
From: Scott Pasnikowski <spasnikowski at semantic-ai.com>
Sent: Friday, January 12, 2024 2:24 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: Current postgis builds broken???
Yesterday I was doing a fresh install of our server package and quickly
recieved error messages that postgis wont install...
This appears to have happened late afternoon (PST).
Does anyone know whats up?
[rocky at sai-int-test-cortex-airflow-test4 singlenode]$ sudo dnf -y install
postgis34_15
Last metadata expiration check: 0:02:48 ago on Fri 12 Jan 2024 07:15:57 PM
UTC.
Error:
Problem: package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires
gdal36-libs >= 3.6.3, but none of the providers can be installed
- package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires
libgdal.so.32()(64bit), but none of the providers can be installed
- cannot install the best candidate for the job
- nothing provides libarmadillo.so.10()(64bit) needed by
gdal36-libs-3.6.4-4PGDG.rhel8.x86_64 from pgdg-common
gdal36-libs-3.6.4-5PGDG.rhel8.x86_64 from pgdg-common
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to
use not only best candidate packages)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240112/c5f8fa10/attachment.htm>
