Current postgis builds broken???
Scott Pasnikowski spasnikowski at semantic-ai.com
Fri Jan 12 12:34:55 PST 2024
Verified epel-release is installed.
Yesterday morning the same postgis install (ansible script) on a clean machine was successful.
Yesterday afternoon these postgis errors started....
Maybe related to...
Postgres has revved their repo files...(as of Jan 2) I think they removed pg11 entry and added a pg17dev entry.   I have had to update multiple pg machines because the simple repo update
invalidated the gpg signature of something.... I needed to download a new repo file and that fixes yum/dnf updates.
Wondering if this may have hit the postgis build farm... just a thought.
S
Sent: Friday, January 12, 2024 12:03 PM
To: Scott Pasnikowski <spasnikowski at semantic-ai.com>; 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: RE: Current postgis builds broken???
Looks like you might be missing epel-release
Did you already do
dnf -y install epel-release
as detailed here - https://postgis.net/documentation/getting_started/install_red_hat/
You might get more answers on the https://www.postgresql.org/list/pgsql-pkg-yum/  mailing list.
Hope that helps,
Regina
From: Scott Pasnikowski <spasnikowski at semantic-ai.com>
Sent: Friday, January 12, 2024 2:24 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: Current postgis builds broken???
Yesterday I was doing a fresh install of our server package and quickly recieved error messages that postgis wont install...
This appears to have happened late afternoon (PST).
Does anyone know whats up?
[rocky at sai-int-test-cortex-airflow-test4 singlenode]$ sudo dnf -y install postgis34_15
Last metadata expiration check: 0:02:48 ago on Fri 12 Jan 2024 07:15:57 PM UTC.
Error:
 Problem: package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires gdal36-libs >= 3.6.3, but none of the providers can be installed
  - package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires libgdal.so.32()(64bit), but none of the providers can be installed
  - cannot install the best candidate for the job
  - nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-4PGDG.rhel8.x86_64 from pgdg-common
  - nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-5PGDG.rhel8.x86_64 from pgdg-common
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240112/83117bc7/attachment.htm>
