Current postgis builds broken???
Devrim Gündüz devrim at gunduz.org
Fri Jan 12 13:17:59 PST 2024
Sorry for the top posting.
Did you enable CRB repo as well? Instructions are here:
https://yum.postgresql.org/howto/
Regards, Devrim
On 12 January 2024 19:24:19 GMT, Scott Pasnikowski <spasnikowski at semantic-ai.com> wrote:
>Yesterday I was doing a fresh install of our server package and quickly recieved error messages that postgis wont install...
>This appears to have happened late afternoon (PST).
>Does anyone know whats up?
>[rocky at sai-int-test-cortex-airflow-test4 singlenode]$ sudo dnf -y install postgis34_15
>Last metadata expiration check: 0:02:48 ago on Fri 12 Jan 2024 07:15:57 PM UTC.
>Error:
> Problem: package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires gdal36-libs >= 3.6.3, but none of the providers can be installed
>  - package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires libgdal.so.32()(64bit), but none of the providers can be installed
>  - cannot install the best candidate for the job
>  - nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-4PGDG.rhel8.x86_64 from pgdg-common
>  - nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-5PGDG.rhel8.x86_64 from pgdg-common
>(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240112/f11cd6f9/attachment.htm>
