Current postgis builds broken???
Joshua Kacsir
joshua.kacsir at crunchydata.com
Fri Jan 12 15:25:11 PST 2024
Good evening,
> Problem: package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15
>> requires gdal36-libs >= 3.6.3, but none of the providers can be installed
>> - package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires
>> libgdal.so.32()(64bit), but none of the providers can be installed
>> - cannot install the best candidate for the job
>> - nothing provides libarmadillo.so.10()(64bit) needed by
>> gdal36-libs-3.6.4-4PGDG.rhel8.x86_64 from pgdg-common
>> gdal36-libs-3.6.4-5PGDG.rhel8.x86_64 from pgdg-common
>> (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
>> to use not only best candidate packages)
Apparently EPEL updated the armadillo package to version 12 without making
it backwards compatible; the older package can be found here however:
https://dl.fedoraproject.org/pub/archive/epel/8.8/Everything/x86_64/Packages/a/
Best Regards,
Joshua Kacsir
Data Architect
www.crunchydata.com
[This email was written *without* the assistance of LLMs]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240112/7478a7c7/attachment.htm>
