Current postgis builds broken???
Scott Pasnikowski
spasnikowski at semantic-ai.com
Sun Jan 14 18:37:45 PST 2024
Verified - Joshua is correct.
Installing the armadillo package from archive as suggested now fixes Postgis install on Rocky.
S
On Jan 12, 2024, at 3:25 PM, Joshua Kacsir <joshua.kacsir at crunchydata.com> wrote:
You don't often get email from joshua.kacsir at crunchydata.com. Learn why this is important<https://aka.ms/LearnAboutSenderIdentification>
Good evening,
Problem: package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires gdal36-libs >= 3.6.3, but none of the providers can be installed
- package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires libgdal.so.32()(64bit), but none of the providers can be installed
- cannot install the best candidate for the job
- nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-4PGDG.rhel8.x86_64 from pgdg-common
- nothing provides libarmadillo.so.10()(64bit) needed by gdal36-libs-3.6.4-5PGDG.rhel8.x86_64 from pgdg-common
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
Apparently EPEL updated the armadillo package to version 12 without making it backwards compatible; the older package can be found here however:
https://dl.fedoraproject.org/pub/archive/epel/8.8/Everything/x86_64/Packages/a/
Best Regards,
Joshua Kacsir
Data Architect
www.crunchydata.com<https://www.crunchydata.com/>
joshua.kacsir at crunchydata.com<mailto:joshua.kacsir at crunchydata.com>
[This email was written *without* the assistance of LLMs]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240115/f20ef45b/attachment.htm>
