Current postgis builds broken???
Devrim Gündüz
devrim at gunduz.org
Tue Jan 16 04:14:04 PST 2024
On Fri, 2024-01-12 at 19:24 +0000, Scott Pasnikowski wrote:
> [rocky at sai-int-test-cortex-airflow-test4 singlenode]$ sudo dnf -y
> install postgis34_15
> Last metadata expiration check: 0:02:48 ago on Fri 12 Jan 2024
> 07:15:57 PM UTC.
> Error:
> Problem: package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15
> requires gdal36-libs >= 3.6.3, but none of the providers can be
> installed
> - package postgis34_15-3.4.1-1PGDG.rhel8.x86_64 from pgdg15 requires
> libgdal.so.32()(64bit), but none of the providers can be installed
> - cannot install the best candidate for the job
> - nothing provides libarmadillo.so.10()(64bit) needed by gdal36-
> libs-3.6.4-4PGDG.rhel8.x86_64 from pgdg-common
> libs-3.6.4-5PGDG.rhel8.x86_64 from pgdg-common
> (try to add '--skip-broken' to skip uninstallable packages or '--
> nobest' to use not only best candidate packages)
Fixed in yesterday's releases. New gdal36 package version is 3.6.4-6.
Regards,
Devrim Gündüz
Open Source Solution Architect, PostgreSQL Major Contributor
Twitter: @DevrimGunduz , @DevrimGunduzTR
