Update postgis in a replicated PostgreSQL 12 database now with postgis-3
Andrew Hardy
andrew.hardy at sabstt.com
Mon Jul 1 08:37:37 PDT 2024
Thank you so much for your response, I appreciate it.
I omitted to mention that before I messaged I had tried to resolve this in
the pg_proc table and ran the following query:
UPDATE pg_proc SET probin = '$libdir/postgis-3' WHERE probin =
'$libdir/rtpostgis-2.5';
This was probably a mistake (not least that postgis-3 is not the raster
library) and I am wondering if this is resolvable.
I have only just discovered the following documentation:
https://postgis.net/documentation/tips/tip-upgrading-raster-from-2-3/
Q1: And I am wondering if the postgis_extensions_upgrade() mentioned in
the upgrade instructions assumes one is starting from a particular state
and I need to get back there from my mistake above or if this upgrade
function will resolve things whatever the state.
Q2: Should I still run postgis_full_version() - is this function a
benign query, unlike postgis_extensions_upgrade() ?
Thanks,
Andrew
On Tue, 25 Jun 2024 at 08:08, Sandro Santilli <strk at kbt.io> wrote:
> Hi Andrew, replies inline
> On Mon, Jun 24, 2024 at 05:38:50PM +0100, Andrew Hardy wrote:
> > We noticed some odd failures executing a SELECT on a table with a point
> > type column. The error was: 'could not access file
> "$libdir/postgis-2.5":
> > No such file or directory' .
> This means you have some left-over old PostGIS functions in your
> database, so the upgrade was not complete. What does the following
> query return ?
> SELECT postgis_full_version()
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240701/8bb11044/attachment.htm>
