GDAL dependencies during PostGIS upgrade
Nikhil Shetty
nikhil.dba04 at gmail.com
Wed Jul 3 23:03:17 PDT 2024
Hi Devrim,
(RPM packager speaking) From packaging point of view this means
> raster2pgsql has the same build id between 13 and 15, so that's why you
> are seeing this error. Let me see if I can do something there. Until
> then please remove postgis33_13 client package as it does not have
> anything to do with the update. After you are done, you can install
> postgis33_15.
Just wanted to check if the dependency due to the same build id is resolved
On Wed, Feb 21, 2024 at 3:51 PM Devrim Gündüz <devrim at gunduz.org> wrote:
> Hi,
> On Tue, 2024-02-20 at 22:37 +0530, Nikhil Shetty wrote:
> > I upgraded the existing PostGIS 3.1.2 to 3.3.5 on PG13 but now when I
> > am trying to install PostGIS 3.3.5 for PG15 , I am getting below error
> > Error: Transaction test error:
> > file /usr/lib/.build-id/b6/89201f4430759c8544cd168dc6ba3e24f7d912
> > from install of postgis33_15-client-3.3.5-1PGDG.rhel8.x86_64 conflicts
> > with file from package postgis33_13-client-3.3.5-1PGDG.rhel8.x86_64
> postgis33_15.
> Regards,
> Devrim Gündüz
> Open Source Solution Architect, PostgreSQL Major Contributor
> Twitter: @DevrimGunduz , @DevrimGunduzTR
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240704/15335aef/attachment.htm>
