raster2pgsql install
Gandalf the Gray pjduplooy.gis at gmail.com
Fri Nov 15 05:49:52 PST 2024
Hi Paolo
https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip
(If you are using PG 17)
QGIS Plugin is Called PostGIS Raster Import (for that you have to have PG
and PostGIS installed)
On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Hi,
> do you mean unpacking the installer and extracting the exe? How about the
> dependencies?
> Which qgis plugin you mean?
> Thanks.
> Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <
> pjduplooy.gis at gmail.com> ha scritto:
>> Hi Paolo
>> Get the zip file of PostGIS.
>> Or, I use the QGIS plugin
>> On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <
>> postgis-users at lists.osgeo.org> wrote:
>>> Hi all.
>>> Is there a way to install raster2pgsql on windows without the full
>>> PG+postgis stack?
>>> If not, what is the suggested way to import rasters from clients?
>>> Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241115/8344bab4/attachment.htm>
