raster2pgsql install
Paolo Cavallini
cavallini at faunalia.it
Mon Nov 18 03:22:58 PST 2024
Thank you Gandalf.
You mean unzipping and extracting the raster2pgsql should work?
As for the plugin, the need to install postgis brings us back to the original problem.
All the best.
Il 15 novembre 2024 12:49:52 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com> ha scritto:
>Hi Paolo
>https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip
>(If you are using PG 17)
>QGIS Plugin is Called PostGIS Raster Import (for that you have to have PG
>and PostGIS installed)
>On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it>
>wrote:
>> Hi,
>> do you mean unpacking the installer and extracting the exe? How about the
>> dependencies?
>> Which qgis plugin you mean?
>> Thanks.
>> Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <
>>> Hi Paolo
>>> Get the zip file of PostGIS.
>>> Or, I use the QGIS plugin
>>> On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <
>>> postgis-users at lists.osgeo.org> wrote:
>>>> Hi all.
>>>> Is there a way to install raster2pgsql on windows without the full
>>>> PG+postgis stack?
>>>> If not, what is the suggested way to import rasters from clients?
>>>> Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241118/3dd0d2c7/attachment.htm>
