raster2pgsql install
Gandalf the Gray
pjduplooy.gis at gmail.com
Mon Nov 18 03:49:08 PST 2024
Hi Paolo
I just tested it, and it works fine. Just keep all the dll's together with
the exes.
Pieter
On Mon, Nov 18, 2024 at 1:23 PM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Thank you Gandalf.
> You mean unzipping and extracting the raster2pgsql should work?
> As for the plugin, the need to install postgis brings us back to the
> original problem.
> All the best.
> Il 15 novembre 2024 12:49:52 GMT-01:00, Gandalf the Gray <
> pjduplooy.gis at gmail.com> ha scritto:
>> Hi Paolo
>> https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip
>> (If you are using PG 17)
>> QGIS Plugin is Called PostGIS Raster Import (for that you have to have PG
>> and PostGIS installed)
>> On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it>
>> wrote:
>>> Hi,
>>> do you mean unpacking the installer and extracting the exe? How about
>>> the dependencies?
>>> Which qgis plugin you mean?
>>> Thanks.
>>> Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <
>>>> Hi Paolo
>>>> Get the zip file of PostGIS.
>>>> Or, I use the QGIS plugin
>>>> On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <
>>>> postgis-users at lists.osgeo.org> wrote:
>>>>> Hi all.
>>>>> Is there a way to install raster2pgsql on windows without the full
>>>>> PG+postgis stack?
>>>>> If not, what is the suggested way to import rasters from clients?
>>>>> Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241118/cdb98762/attachment.htm>
