raster2pgsql install
Gandalf the Gray
pjduplooy.gis at gmail.com
Mon Nov 18 03:50:17 PST 2024
Sorry, I meant to implicate that extracting works
On Mon, Nov 18, 2024 at 1:49 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
wrote:
> Hi Paolo
> I just tested it, and it works fine. Just keep all the dll's together
> with the exes.
> Pieter
> On Mon, Nov 18, 2024 at 1:23 PM Paolo Cavallini <cavallini at faunalia.it>
> wrote:
>> Thank you Gandalf.
>> You mean unzipping and extracting the raster2pgsql should work?
>> As for the plugin, the need to install postgis brings us back to the
>> original problem.
>> All the best.
>> Il 15 novembre 2024 12:49:52 GMT-01:00, Gandalf the Gray <
>> pjduplooy.gis at gmail.com> ha scritto:
>>> Hi Paolo
>>> https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip
>>> (If you are using PG 17)
>>> QGIS Plugin is Called PostGIS Raster Import (for that you have to have
>>> PG and PostGIS installed)
>>> On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it>
>>> wrote:
>>>> Hi,
>>>> do you mean unpacking the installer and extracting the exe? How about
>>>> the dependencies?
>>>> Which qgis plugin you mean?
>>>> Thanks.
>>>> Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <
>>>>> Hi Paolo
>>>>> Get the zip file of PostGIS.
>>>>> Or, I use the QGIS plugin
>>>>> On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <
>>>>> postgis-users at lists.osgeo.org> wrote:
>>>>>> Hi all.
>>>>>> Is there a way to install raster2pgsql on windows without the full
>>>>>> PG+postgis stack?
>>>>>> If not, what is the suggested way to import rasters from clients?
>>>>>> Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241118/25eb08b2/attachment.htm>
