raster2pgsql install
Paolo Cavallini cavallini at faunalia.it
Mon Nov 18 03:55:39 PST 2024
Thanks a lot.
May I suggest the packagers to create another zip just with it? This would make things far easier for most people.
Cheers.
Il 18 novembre 2024 10:50:17 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com> ha scritto:
>Sorry, I meant to implicate that extracting works
>On Mon, Nov 18, 2024 at 1:49 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
>wrote:
>> Hi Paolo
>> I just tested it, and it works fine.  Just keep all the dll's together
>> with the exes.
>> Pieter
>> On Mon, Nov 18, 2024 at 1:23 PM Paolo Cavallini <cavallini at faunalia.it>
>> wrote:
>>> Thank you Gandalf.
>>> You mean unzipping and extracting the raster2pgsql should work?
>>> As for the plugin, the need to install postgis brings us back to the
>>> original problem.
>>> All the best.
>>> Il 15 novembre 2024 12:49:52 GMT-01:00, Gandalf the Gray <
>>>> Hi Paolo
>>>> https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip
>>>> (If you are using PG 17)
>>>> QGIS Plugin is Called PostGIS Raster Import (for that you have to have
>>>> PG and PostGIS installed)
>>>> On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it>
>>>> wrote:
>>>>> Hi,
>>>>> do you mean unpacking the installer and extracting the exe? How about
>>>>> the dependencies?
>>>>> Which qgis plugin you mean?
>>>>> Thanks.
>>>>> Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <
>>>>>> Hi Paolo
>>>>>> Get the zip file of PostGIS.
>>>>>> Or, I use the QGIS plugin
>>>>>> On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <
>>>>>> postgis-users at lists.osgeo.org> wrote:
>>>>>>> Hi all.
>>>>>>> Is there a way to install raster2pgsql on windows without the full
>>>>>>> PG+postgis stack?
>>>>>>> If not, what is the suggested way to import rasters from clients?
>>>>>>> Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241118/a072dd13/attachment.htm>
