raster2pgsql install
Gandalf the Gray
pjduplooy.gis at gmail.com
Mon Nov 18 05:45:54 PST 2024
Hi Paolo
I just dont have an idea which dll's go with raster2pgsql
On Mon, Nov 18, 2024 at 1:55 PM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Thanks a lot.
> May I suggest the packagers to create another zip just with it? This would
> make things far easier for most people.
> Cheers.
> Il 18 novembre 2024 10:50:17 GMT-01:00, Gandalf the Gray <
> pjduplooy.gis at gmail.com> ha scritto:
>> Sorry, I meant to implicate that extracting works
>> On Mon, Nov 18, 2024 at 1:49 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
>> wrote:
>>> Hi Paolo
>>> I just tested it, and it works fine. Just keep all the dll's together
>>> with the exes.
>>> Pieter
>>> On Mon, Nov 18, 2024 at 1:23 PM Paolo Cavallini <cavallini at faunalia.it>
>>> wrote:
>>>> Thank you Gandalf.
>>>> You mean unzipping and extracting the raster2pgsql should work?
>>>> As for the plugin, the need to install postgis brings us back to the
>>>> original problem.
>>>> All the best.
>>>> Il 15 novembre 2024 12:49:52 GMT-01:00, Gandalf the Gray <
>>>>> Hi Paolo
>>>>> https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip
>>>>> (If you are using PG 17)
>>>>> QGIS Plugin is Called PostGIS Raster Import (for that you have to have
>>>>> PG and PostGIS installed)
>>>>> On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it>
>>>>> wrote:
>>>>>> Hi,
>>>>>> do you mean unpacking the installer and extracting the exe? How about
>>>>>> the dependencies?
>>>>>> Which qgis plugin you mean?
>>>>>> Thanks.
>>>>>> Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <
>>>>>>> Hi Paolo
>>>>>>> Get the zip file of PostGIS.
>>>>>>> Or, I use the QGIS plugin
>>>>>>> On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <
>>>>>>> postgis-users at lists.osgeo.org> wrote:
>>>>>>>> Hi all.
>>>>>>>> Is there a way to install raster2pgsql on windows without the full
>>>>>>>> PG+postgis stack?
>>>>>>>> If not, what is the suggested way to import rasters from clients?
>>>>>>>> Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241118/e2ffd3f5/attachment.htm>
