raster2pgsql install
    Regina Obe
    lr at pcorp.us
    Mon Nov 18 07:56:29 PST 2024
Paolo,
I think a long time ago I used to have the commandline tools also available as a separate download.  I guess I can start that again if enough people find that valuable.
From: Gandalf the Gray <pjduplooy.gis at gmail.com>
Sent: Monday, November 18, 2024 8:46 AM
To: Paolo Cavallini <cavallini at faunalia.it>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: raster2pgsql install
Hi Paolo
I just dont have an idea which dll's go with raster2pgsql
On Mon, Nov 18, 2024 at 1:55 PM Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it> > wrote:
Thanks a lot.
May I suggest the packagers to create another zip just with it? This would make things far easier for most people.
Cheers.
Il 18 novembre 2024 10:50:17 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > ha scritto:
Sorry, I meant to implicate that extracting works
On Mon, Nov 18, 2024 at 1:49 PM Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > wrote:
Hi Paolo
I just tested it, and it works fine.  Just keep all the dll's together with the exes.
Pieter
On Mon, Nov 18, 2024 at 1:23 PM Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it> > wrote:
Thank you Gandalf.
You mean unzipping and extracting the raster2pgsql should work?
As for the plugin, the need to install postgis brings us back to the original problem.
All the best.
Il 15 novembre 2024 12:49:52 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > ha scritto:
Hi Paolo
https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip (If you are using PG 17)
QGIS Plugin is Called PostGIS Raster Import (for that you have to have PG and PostGIS installed)
On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it> > wrote:
do you mean unpacking the installer and extracting the exe? How about the dependencies?
Which qgis plugin you mean?
Thanks.
Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > ha scritto:
Hi Paolo
Get the zip file of PostGIS.
Or, I use the QGIS plugin
On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> > wrote:
Hi all.
Is there a way to install raster2pgsql on windows without the full PG+postgis stack?
If not, what is the suggested way to import rasters from clients?
Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241118/1861deb6/attachment.htm>
