raster2pgsql install
Paolo Cavallini
cavallini at faunalia.it
Mon Nov 18 10:23:22 PST 2024
Thanks Régina
Il 18 novembre 2024 14:56:29 GMT-01:00, Regina Obe <lr at pcorp.us> ha scritto:
>Paolo,
>I think a long time ago I used to have the commandline tools also available as a separate download. I guess I can start that again if enough people find that valuable.
>From: Gandalf the Gray <pjduplooy.gis at gmail.com>
>Sent: Monday, November 18, 2024 8:46 AM
>To: Paolo Cavallini <cavallini at faunalia.it>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>Subject: Re: raster2pgsql install
>Hi Paolo
>I just dont have an idea which dll's go with raster2pgsql
>On Mon, Nov 18, 2024 at 1:55 PM Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it> > wrote:
>Thanks a lot.
>May I suggest the packagers to create another zip just with it? This would make things far easier for most people.
>Cheers.
>Il 18 novembre 2024 10:50:17 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > ha scritto:
>Sorry, I meant to implicate that extracting works
>On Mon, Nov 18, 2024 at 1:49 PM Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > wrote:
>Hi Paolo
>I just tested it, and it works fine. Just keep all the dll's together with the exes.
>Pieter
>On Mon, Nov 18, 2024 at 1:23 PM Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it> > wrote:
>Thank you Gandalf.
>You mean unzipping and extracting the raster2pgsql should work?
>As for the plugin, the need to install postgis brings us back to the original problem.
>All the best.
>Il 15 novembre 2024 12:49:52 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > ha scritto:
>Hi Paolo
>https://winnie.postgis.net/download/windows/pg17/buildbot/postgis-bundle-pg17-3.5.0x64.zip (If you are using PG 17)
>QGIS Plugin is Called PostGIS Raster Import (for that you have to have PG and PostGIS installed)
>On Fri, Nov 15, 2024 at 3:02 PM Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it> > wrote:
>Hi,
>do you mean unpacking the installer and extracting the exe? How about the dependencies?
>Which qgis plugin you mean?
>Thanks.
>Il 15 novembre 2024 10:18:01 GMT-01:00, Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > ha scritto:
>Hi Paolo
>Get the zip file of PostGIS.
>Or, I use the QGIS plugin
>On Fri, Nov 15, 2024 at 12:25 PM Paolo Cavallini via postgis-users <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> > wrote:
>Hi all.
>Is there a way to install raster2pgsql on windows without the full PG+postgis stack?
>If not, what is the suggested way to import rasters from clients?
>Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241118/4cb9e8ba/attachment.htm>
