RE: Updating PostGIS from 3.5.0alpha2 —> 3.5.0 error
Regina Obe lr at pcorp.us
Fri Nov 15 07:36:30 PST 2024
Not sure how you ended up with an alpha2,  I had removed that in the final release thinking no one would be running with that that wasn’t building there own.
To fix:
UPDATE pg_extension SET extversion = 'ANY' where extname LIKE 'postgis%';
And then run the process again.
From: Anthony DeBarros <anthonymdebarros at gmail.com>
Sent: Friday, November 15, 2024 7:21 AM
To: postgis-users at lists.osgeo.org
Subject: Updating PostGIS from 3.5.0alpha2 —> 3.5.0 error
Hi, folks,
I am running PostgresApp on a Mac and recently updated it to PostgreSQL version 17.1.
While running SELECT postgis_extensions_upgrade(); I get the following error:
NOTICE:  Updating extension postgis 3.5.0alpha2
ERROR:  extension "postgis" has no update path from version "3.5.0alpha2" to version "ANY"
CONTEXT:  SQL statement "ALTER EXTENSION postgis UPDATE TO "ANY";ALTER EXTENSION postgis UPDATE TO "3.5.0""
PL/pgSQL function postgis_extensions_upgrade(text) line 88 at EXECUTE
Any advice on how to update?
Thanks!
Anthony DeBarros
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241115/822f47e1/attachment.htm>
