Re: Updating PostGIS from 3.5.0alpha2 —> 3.5.0 error
Anthony DeBarros
anthonymdebarros at gmail.com
Fri Nov 15 07:50:30 PST 2024
Thanks! Worked like a charm.
I think the makers of Postgres App included the alpha version in a beta of
17 at some point.
On Nov 15, 2024 at 10:36:30 AM, Regina Obe <lr at pcorp.us> wrote:
> Not sure how you ended up with an alpha2, I had removed that in the final
> release thinking no one would be running with that that wasn’t building
> there own.
> To fix:
> UPDATE pg_extension SET extversion = 'ANY' where extname LIKE 'postgis%';
> And then run the process again.
> *From:* Anthony DeBarros <anthonymdebarros at gmail.com>
> *Sent:* Friday, November 15, 2024 7:21 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Updating PostGIS from 3.5.0alpha2 —> 3.5.0 error
> Hi, folks,
> I am running PostgresApp on a Mac and recently updated it to PostgreSQL
> version 17.1.
> While running SELECT postgis_extensions_upgrade(); I get the following
> error:
> NOTICE: Updating extension postgis 3.5.0alpha2
> ERROR: extension "postgis" has no update path from version "3.5.0alpha2"
> to version "ANY"
> CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO "ANY";ALTER
> EXTENSION postgis UPDATE TO "3.5.0""
> PL/pgSQL function postgis_extensions_upgrade(text) line 88 at EXECUTE
> Any advice on how to update?
> Thanks!
> Anthony DeBarros
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241115/86d69d8a/attachment.htm>
