Failure during Postgres major version upgrade due to deprecated long_xact funcs
Regina Obe lr at pcorp.us
Tue Oct 8 12:14:09 PDT 2024
Thanks for the alert.  I suspect we forgot to add that function to postgis_legacy, so that needs to be done.  We’ll do that in next 3.4. patch update.
For now I recommend before upgrading (especially with pg_upgrade) dropping it in the extension.
So
ALTER EXTENSION "postgis" DROP FUNCTION "public"."checkauthtrigger"() CASCADE;
Sent: Tuesday, October 8, 2024 12:23 PM
To: postgis-users at lists.osgeo.org
Subject: Failure during Postgres major version upgrade due to deprecated long_xact funcs
Hi there,
I saw postgres upgrade failure with following message (pg16.1 to 17.0, postgis 3.4.0 to postgis 3.5.0)
pg_restore: creating FUNCTION "public.checkauth("text", "text", "text")"
pg_restore: creating COMMENT "public.FUNCTION "checkauth"("text", "text", "text")"
pg_restore: creating FUNCTION "public.checkauthtrigger()"
pg_restore: while PROCESSING TOC:
pg_restore: from TOC entry 558; 1255 18735 FUNCTION checkauthtrigger() pguser
pg_restore: error: could not execute query: ERROR:  could not find function "check_authorization" in file "/local/home/pguser/temp/local_pg/installs/pg170/lib/postgresql/postgis-3.so"
Command was: CREATE FUNCTION "public"."checkauthtrigger"() RETURNS "trigger"
    LANGUAGE "c"
    AS '$libdir/postgis-3', 'check_authorization';
-- For binary upgrade, handle extension membership the hard way
ALTER EXTENSION "postgis" ADD FUNCTION "public"."checkauthtrigger"();
(same for GetTransactionID)
I saw a previous ticket https://trac.osgeo.org/postgis/ticket/5723  which tried to drop it already, but I still see this. Is this expected or something that was missed during testing?
Best,
Derek
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241008/e38e5b59/attachment.htm>
