Failure during Postgres major version upgrade due to deprecated long_xact funcs
Regina Obe
lr at pcorp.us
Tue Oct 8 13:37:01 PDT 2024
We haven’t decided on a patch version release date. I’m thinking a little before PostgreSQL 17.1 would be a good time, to catch the bulk of new folks upgrading.
I’ve ticketed the issue here - https://trac.osgeo.org/postgis/ticket/5791 and will address this week.
Thanks for the report,
Regina
Sent: Tuesday, October 8, 2024 3:46 PM
To: Regina Obe <lr at pcorp.us>
Subject: Re: Failure during Postgres major version upgrade due to deprecated long_xact funcs
Hi Regina,
After adding those two to postgis_legacy.c and rebuilding it, now upgrade can complete. Thanks for the help!
Upgrade Complete
Optimizer statistics are not transferred by pg_upgrade.
Once you start the new server, consider running:
May I know when the new patch version will be released?
Derek
On Tue, Oct 8, 2024 at 12:14 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Thanks for the alert. I suspect we forgot to add that function to postgis_legacy, so that needs to be done. We’ll do that in next 3.4. patch update.
For now I recommend before upgrading (especially with pg_upgrade) dropping it in the extension.
So
ALTER EXTENSION "postgis" DROP FUNCTION "public"."checkauthtrigger"() CASCADE;
From: Kered <dereksunpublic at gmail.com <mailto:dereksunpublic at gmail.com> >
Sent: Tuesday, October 8, 2024 12:23 PM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: Failure during Postgres major version upgrade due to deprecated long_xact funcs
Hi there,
I saw postgres upgrade failure with following message (pg16.1 to 17.0, postgis 3.4.0 to postgis 3.5.0)
pg_restore: creating FUNCTION "public.checkauth("text", "text", "text")"
pg_restore: creating COMMENT "public.FUNCTION "checkauth"("text", "text", "text")"
pg_restore: creating FUNCTION "public.checkauthtrigger()"
pg_restore: while PROCESSING TOC:
pg_restore: from TOC entry 558; 1255 18735 FUNCTION checkauthtrigger() pguser
pg_restore: error: could not execute query: ERROR: could not find function "check_authorization" in file "/local/home/pguser/temp/local_pg/installs/pg170/lib/postgresql/postgis-3.so"
Command was: CREATE FUNCTION "public"."checkauthtrigger"() RETURNS "trigger"
LANGUAGE "c"
AS '$libdir/postgis-3', 'check_authorization';
-- For binary upgrade, handle extension membership the hard way
ALTER EXTENSION "postgis" ADD FUNCTION "public"."checkauthtrigger"();
(same for GetTransactionID)
I saw a previous ticket https://trac.osgeo.org/postgis/ticket/5723 which tried to drop it already, but I still see this. Is this expected or something that was missed during testing?
Best,
Derek
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241008/1e951be9/attachment.htm>
