PostGIS 3.4.x - Error while compile make install
Jorge Gustavo Rocha
jgr at di.uminho.pt
Mon Sep 16 09:43:03 PDT 2024
Hi Mirko,
You need to run the install with root privileges.
sudo make install
Regards,
Jorge
On 16/09/24 16:38, Auberg, Mirko wrote:
> Hello PotGIS Users,
> i try to compile PostGIS 3.4.3 with PostgreSQL 16.4.
> My configure Option are this:
> ./configure
> --with-pgconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/bin/pg_config
> --with-geosconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/usr/bin/geos-config
> --with-gdalconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/usr/bin/gdal-config
> --with-projdir=/usr/proj63/ --with-sfcgal --without-protobuf
> OS: RedHat 8
> GEOS Version 3.12.2
> GDAL: Version 3.9.2
> Proj: Version 6.3
> Im getting at “make install” following Error.
> make -C loader install
> make[2]: Entering directory
> '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster/loader'
> /bin/sh ../../libtool --mode=install /usr/bin/install -c raster2pgsql
> "/usr/local/bin/raster2pgsql"
> libtool: install: /usr/bin/install -c raster2pgsql
> /usr/bin/install: cannot create regular file
> '/usr/local/bin/raster2pgsql': Permission denied
> make[2]: *** [Makefile:97: install] Error 1
> make[2]: Leaving directory
> make[1]: *** [Makefile:50: install] Error 2
> make[1]: Leaving directory
> '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster'
> make: *** [GNUmakefile:25: install] Error 1
> Seems like a Bug to me. I have the error just with Version 3.4.x. With
> older Version is no Problem. Looks like the compiler forgets the
> pg_config Location an tries to install in the usual OS Path.
> Does somebody know the problem or can open a Bug Ticket?
> Regards,
> Mirko
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240916/9a0c5b41/attachment.htm>
