PostGIS 3.4.x - Error while compile make install
Auberg, Mirko
Mirko.Auberg at btc-it-services.com
Mon Sep 16 08:38:07 PDT 2024
Hello PotGIS Users,
i try to compile PostGIS 3.4.3 with PostgreSQL 16.4.
My configure Option are this:
./configure --with-pgconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/bin/pg_config --with-geosconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/usr/bin/geos-config --with-gdalconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/usr/bin/gdal-config --with-projdir=/usr/proj63/ --with-sfcgal --without-protobuf
OS: RedHat 8
GEOS Version 3.12.2
GDAL: Version 3.9.2
Proj: Version 6.3
Im getting at "make install" following Error.
make -C loader install
make[2]: Entering directory '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster/loader'
/bin/sh ../../libtool --mode=install /usr/bin/install -c raster2pgsql "/usr/local/bin/raster2pgsql"
libtool: install: /usr/bin/install -c raster2pgsql /usr/local/bin/raster2pgsql
/usr/bin/install: cannot create regular file '/usr/local/bin/raster2pgsql': Permission denied
make[2]: *** [Makefile:97: install] Error 1
make[2]: Leaving directory '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster/loader'
make[1]: *** [Makefile:50: install] Error 2
make[1]: Leaving directory '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster'
make: *** [GNUmakefile:25: install] Error 1
Seems like a Bug to me. I have the error just with Version 3.4.x. With older Version is no Problem. Looks like the compiler forgets the pg_config Location an tries to install in the usual OS Path.
Does somebody know the problem or can open a Bug Ticket?
Regards,
Mirko
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240916/4d3162b1/attachment.htm>
