Can't upgrade to PostGIS 3.4.3, not listed by apt as upgrade.
Imre Samu pella.samu at gmail.com
Sat Sep 14 07:41:10 PDT 2024
Based on the build matrix [amd64, arm64, i386, ppc64el, s390x],
more and more builds are successfully completing.
https://pgdgbuild.dus.dg-i.net/job/postgis-binaries/399/
I expect the (debian+ubuntu) PostGIS 3.4.3 pkg announcement
to come sometime next week.
After the announcement,
I will also need to update the https://github.com/postgis/docker-postgis
 repo
and the postgis/postgis Docker images.
Imre
Marco Boeringa <marco at boeringa.demon.nl> ezt írta (időpont: 2024. szept.
14., Szo, 15:50):
> Ah, thanks Imre, that clears up the confusion. I am not to familiar with
> apt and the release processes of Debian / Ubuntu packages, but since
> everything else seemed fine, and 3.4.3 was announced here in the PostGIS
> list and visible in the repo, I falsely assumed that it should already be
> fully available for Debian / Ubuntu, and that something might be wrong with
> my local apt cache (although commands like 'apt list -a
> postgresql-16-postgis-3' seemed to confirm the current situation, and other
> apt commands reported no issues as well).
> Marco
> Op 14-9-2024 om 15:42 schreef Imre Samu:
>> Even though I see PostGIS 3.4.3 for PostgreSQL 16 listed on the
>> PostgreSQL apt repository since September the 12th
>> (https://apt.postgresql.org/pub/repos/apt/pool/main/p/postgis/), from
>> which I installed it in the distant past and that is set in Ubuntu as
>> the apt source for PostgreSQL, I do not see this upgrade being listed in
>> Ubuntu when I run e.g. Software Updates of Synaptic.
> PostGIS 3.4.3 is not yet available on Debian, and it hasn't been announced
> on the pgsql-pkg-debian mailing list [
> https://www.postgresql.org/list/pgsql-pkg-debian/2024-09/ ] either, where
> I can also see the details for debian+ubuntu.
> For example, the Postgis 3.4.2+dfsg-1.pgdg+1 update announcement contains
> information for both Debian (bookworm, bullseye,...) and Ubuntu (noble,
> mantic, lunar, jammy, focal).
> https://www.postgresql.org/message-id/E1raeuw-00BHqF-A6@atalia.postgresql.org
> I'm expecting a similar announcement for PostGIS 3.4.3 as well.
> In other words, I monitor the "pgsql-pkg-debian" mailing list,
> and I usually see the updated packages within an hour after the email is
> sent.
> Imre
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240914/c87337d6/attachment.htm>
