ST_ClipByBox2D and NaN Coordinates for POLYGON Z
Paul Ramsey
pramsey at cleverelephant.ca
Thu Apr 3 14:45:31 PDT 2025
“Works for me”, what’s your version collection?
pramsey=# select postgis_full_version();
POSTGIS="3.6.0dev 3.5.0-228-g2c8f40113" [EXTENSION] PGSQL="170" GEOS="3.14.0dev-CAPI-1.20.0" PROJ="9.3.0 NETWORK_ENABLED=ON URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0) GDAL="GDAL 3.9.3, released 2024/12/10 (debug build)" LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" (core procs from "3.6.0dev 3.5.0-186-g2845d3f37" need upgrade) RASTER (raster lib from "3.5.0 3.5.0-211-g202d59f44" need upgrade) (raster procs from "3.5.0 3.5.0" need upgrade)
> On Apr 3, 2025, at 2:43 PM, Denis Rykov <rykovd at gmail.com> wrote:
> Is it expected for ST_ClipByBox2D to return NaN coordinates for 'POLYGON Z' geometries?
> Here is an example. The following SQL query:
> SELECT
> ST_AsText(
> ST_SimplifyPreserveTopology(
> ST_ClipByBox2D(
> ST_GeomFromText(
> 'POLYGON Z ((9109727.260586184 7235765.611871982 0,9109793.397475857 7235780.37911723 0,9109880.551536862 7235799.226171476 0,9109912.974452058 7235743.263961895 0,9109949.41754929 7235677.287550647 0,9109986.927785816 7235610.625640362 0,9110029.388466287 7235535.445041807 0,9110063.152192863 7235481.075809712 0,9110058.528985653 7235478.79780619 0,9110066.094453445 7235463.4091950925 0,9110094.816342745 7235418.349932027 0,9110128.716586944 7235357.442269537 0,9110170.311475156 7235283.992565744 0,9110207.570403146 7235217.92016041 0,9110271.536255063 7235090.866183731 0,9110290.55592083 7235042.889807568 0,9110192.389007365 7235014.391634338 0,9110169.194172846 7235007.739006326 0,9109951.366830455 7235432.506918687 0,9109937.453975307 7235459.0955318 0,9109797.566462943 7235663.435298668 0,9109727.260586184 7235765.611871982 0))'
> ST_MakeEnvelope(
> 9108725.486174684, 7235101.049109253,
> 9111416.069569945, 7237791.632504516
> 5
> fails with the 'Geometry contains invalid coordinates' error, but wrapping the geometry in ST_Force2D makes it work.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250403/21545e92/attachment.htm>
