ST_ClipByBox2D and NaN Coordinates for POLYGON Z
Denis Rykov rykovd at gmail.com
Thu Apr 3 14:49:47 PDT 2025
Thanks for the quick response, Paul!
$ select postgis_full_version();
POSTGIS="3.5.2 dea6d0a" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3"
WAGYU="0.5.0 (I
nternal)"
(1 row)
On Thu, Apr 3, 2025 at 11:45 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> “Works for me”, what’s your version collection?
> pramsey=# select postgis_full_version();
>  POSTGIS="3.6.0dev 3.5.0-228-g2c8f40113" [EXTENSION] PGSQL="170"
> GEOS="3.14.0dev-CAPI-1.20.0" PROJ="9.3.0 NETWORK_ENABLED=ON URL_ENDPOINT=
> https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
> DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
> GDAL="GDAL 3.9.3, released 2024/12/10 (debug build)" LIBXML="2.9.13"
> LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" (core procs
> from "3.6.0dev 3.5.0-186-g2845d3f37" need upgrade) RASTER (raster lib from
> "3.5.0 3.5.0-211-g202d59f44" need upgrade) (raster procs from "3.5.0 3.5.0"
> need upgrade)
> On Apr 3, 2025, at 2:43 PM, Denis Rykov <rykovd at gmail.com> wrote:
> Is it expected for ST_ClipByBox2D to return NaN coordinates for 'POLYGON
> Z' geometries?
> Here is an example. The following SQL query:
> SELECT
>   ST_AsText(
>     ST_SimplifyPreserveTopology(
>       ST_ClipByBox2D(
>         ST_GeomFromText(
>           'POLYGON Z ((9109727.260586184 7235765.611871982
> 0,9109793.397475857 7235780.37911723 0,9109880.551536862 7235799.226171476
> 0,9109912.974452058 7235743.263961895 0,9109949.41754929 7235677.287550647
> 0,9109986.927785816 7235610.625640362 0,9110029.388466287 7235535.445041807
> 0,9110063.152192863 7235481.075809712 0,9110058.528985653 7235478.79780619
> 0,9110066.094453445 7235463.4091950925 0,9110094.816342745
> 7235418.349932027 0,9110128.716586944 7235357.442269537 0,9110170.311475156
> 7235283.992565744 0,9110207.570403146 7235217.92016041 0,9110271.536255063
> 7235090.866183731 0,9110290.55592083 7235042.889807568 0,9110192.389007365
> 7235014.391634338 0,9110169.194172846 7235007.739006326 0,9109951.366830455
> 7235432.506918687 0,9109937.453975307 7235459.0955318 0,9109797.566462943
> 7235663.435298668 0,9109727.260586184 7235765.611871982 0))'
>         ST_MakeEnvelope(
>           9108725.486174684, 7235101.049109253,
>           9111416.069569945, 7237791.632504516
>       5
> fails with the 'Geometry contains invalid coordinates' error, but wrapping
> the geometry in ST_Force2D makes it work.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250403/4243a9db/attachment.htm>
