Why does the raster type not have send/receive defined?
Lukas Panhirsch
lukas.panhirsch at senselabs.de
Tue Apr 8 08:30:16 PDT 2025
That makes sense, thank you both.
I believe I've seen some performance improvements with COPY instead of
INSERT for large amounts of vector rows against a PostgreSQL server with
relatively high storage latency, but on the other hand I'm inserting far
fewer rows in the raster case, so I doubt I'd see the same improvement
there.
Sincerely,
Lukas
On 4/8/25 17:18, Paul Ramsey wrote:
> Yes this. The utility of the send/recv function are in supporting a
> client that is using a binary cursor. This doesn’t even happen much for
> vector data anymore (there was a brief period when we all felt it was de
> rigeur, and then it got benchmarked and it wasn’t that noticeable at all
> as a performance tweak, so everyone stopped, because it added
complexity).
> P
>> On Apr 8, 2025, at 8:15 AM, <lr at pcorp.us> <lr at pcorp.us> wrote:
>> I think it’s because postgis raster is not an OGC standard or any kind
>> of standard outside of PostGIS so there hasn’t been much need for it.
>> For example if you wanted to backup your postgis raster table, you’d
>> just use standard pg_dump / pg_restore tools.
>> Most use cases beyond that are importing from a different raster
>> format or exporting to a different raster format which functions
>> https://postgis.net/docs/en/RT_ST_FromGDALRaster.html <https://
>> postgis.net/docs/en/RT_ST_FromGDALRaster.html>
>> andhttps://postgis.net/docs/en/RT_ST_AsGDALRaster.html <https://
>> postgis.net/docs/en/RT_ST_AsGDALRaster.html>
>> as well as the raster2pgsql commandline tool.
>> *From:*Lukas Panhirsch via postgis-users <postgis-users at lists.osgeo.org>
>> *Sent:*Tuesday, April 8, 2025 9:28 AM
>> *To:*postgis-users at lists.osgeo.org
>> *Subject:*Why does the raster type not have send/receive defined?
>> Hello,
>> I haven't used this mailing list before and couldn't figure out how to
>> search in the archives, so I apologize if this has been answered before.
>> Is there any specific reason why the raster type does not have the
>> send/receive functions in its SQL type definition?
>> The geometry type has these defined as conversions to/from EWKB, which
>> are equivalent to ST_AsEWKB/ST_GeomFromEWKB if I understand correctly.
>> Equivalent (E?)WKB conversion functions exist for rasters in the form
>> of (RT_)ST_AsBinary/ST_RastFromWKB, but have to be called explicitly.
>> I would like to use PostgreSQL features like COPY ... WITH BINARY with
>> rasters, but it seems this is preventing me from doing so.
>> Sincerely,
>> Lukas
