Why does the raster type not have send/receive defined?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Apr 8 08:59:15 PDT 2025
> On Apr 8, 2025, at 8:52 AM, Lukas Panhirsch <lukas.panhirsch at senselabs.de> wrote:
> Does this mean that a PR adding this would be considered?
> I don't desperately need it, but considering my code directly
> encodes/decodes WKB, using binary send/recv would be more efficient and
> simpler than converting it to/from HEX first.
Sure, that would be a fine PR.
Word of warning on getting all excited about binary cursors, you have to push *all* the data through the binary cursor, so you need to send the ints as ints, and the varchars as the postgresql binary storage format for varchar, etc, etc. Also binary cursors are finicky about only being run in transaction in a way text cursors don’t seem to be, so you have to be careful to begin/commit around things cleanly (this was a real problem with the mapserver driver for a long time, and something that got a lot simpler when we just stopped using binary cursors anymore… mind you that was reading not writing, so it felt even more annoying to have to worry over neatly handling transactions for reads)
p.
> On 4/8/25 17:48, Paul Ramsey wrote:
>>> On Apr 8, 2025, at 8:46 AM, Lukas Panhirsch <lukas.panhirsch at senselabs.de> wrote:
>>> Huh, I wouldn't have expected that, I guess I'll have to benchmark, thanks!
>>> Though also, if the reasoning for not having binary send/recv is that
>>> the format is not standardized, wouldn't the same apply to the text format?
>> That’s not the reasoning. The reasoning is we never had anyone who desperately felt they needed send/recv, so they were never implemented. All the code is there, so it would be an easy addition. Nobody has bothered.
>> P.
>>> Or was the text format considered fast enough that binary send/recv is
>>> redundant?
>>> On 4/8/25 17:44, Paul Ramsey wrote:
>>>>> On Apr 8, 2025, at 8:41 AM, Lukas Panhirsch <lukas.panhirsch at senselabs.de> wrote:
>>>>> From what I understand I'd be prevented from using the BINARY format
>>>>> though, as it relies on send/recv. The available alternative would be to
>>>>> use the TEXT format of the raster, which is effectively just the binary
>>>>> WKB encoded in ASCII HEX. And I'd assume that the bandwidth and
>>>> This is the same assume that we held and then discarded back in the day. Hexdecoding is cheap cheap cheap. The win of using COPY over INSERT is orders of magnitude higher than any overhead from the hex encoding. If you’re worried about network bandwidth, connect over SSL which includes a compression layer.
>>>> ATB
>>>> P
>>>>> computational overhead of said TEXT form is too high to be more
>>>>> efficient than simple INSERTs using the binary format+ST_RastFromWKB for
>>>>> a relatively low amount of rows, though I could be wrong.
>>>>> Sincerely,
>>>>> Lukas
>>>>> On 4/8/25 17:31, Paul Ramsey wrote:
>>>>>> Copy vs insert is legit going to be faster, but that’s not a binary
>>>>>> cursor thing, it’s batching up all the transactions and parsing nicely
>>>>>> into one big bundle as COPY does. You should still be able to do a bulk
>>>>>> copy without using send/recv.
>>>>>> P
>>>>>>> On Apr 8, 2025, at 8:30 AM, Lukas Panhirsch
>>>>>>> That makes sense, thank you both.
>>>>>>> I believe I've seen some performance improvements with COPY instead of
>>>>>>> INSERT for large amounts of vector rows against a PostgreSQL server with
>>>>>>> relatively high storage latency, but on the other hand I'm inserting far
>>>>>>> fewer rows in the raster case, so I doubt I'd see the same improvement
>>>>>>> there.
>>>>>>> Sincerely,
>>>>>>> Lukas
>>>>>>> On 4/8/25 17:18, Paul Ramsey wrote:
>>>>>>>> Yes this. The utility of the send/recv function are in supporting a
>>>>>>>> client that is using a binary cursor. This doesn’t even happen much for
>>>>>>>> vector data anymore (there was a brief period when we all felt it was de
>>>>>>>> rigeur, and then it got benchmarked and it wasn’t that noticeable at all
>>>>>>>> as a performance tweak, so everyone stopped, because it added
>>>>>>> complexity).
>>>>>>>> P
>>>>>>>>> On Apr 8, 2025, at 8:15 AM, <lr at pcorp.us> <lr at pcorp.us> wrote:
>>>>>>>>> I think it’s because postgis raster is not an OGC standard or any kind
>>>>>>>>> of standard outside of PostGIS so there hasn’t been much need for it.
>>>>>>>>> For example if you wanted to backup your postgis raster table, you’d
>>>>>>>>> just use standard pg_dump / pg_restore tools.
>>>>>>>>> Most use cases beyond that are importing from a different raster
>>>>>>>>> format or exporting to a different raster format which functions
>>>>>>>>> https://postgis.net/docs/en/RT_ST_FromGDALRaster.html <https://
>>>>>>> postgis.net/docs/en/RT_ST_FromGDALRaster.html><https://
>>>>>>>>> postgis.net/docs/en/RT_ST_FromGDALRaster.html <http://postgis.net/
>>>>>>> docs/en/RT_ST_FromGDALRaster.html>>
>>>>>>>>> andhttps://postgis.net/docs/en/RT_ST_AsGDALRaster.html <andhttps://
>>>>>>> postgis.net/docs/en/RT_ST_AsGDALRaster.html><https://
>>>>>>>>> postgis.net/docs/en/RT_ST_AsGDALRaster.html <http://postgis.net/docs/
>>>>>>> en/RT_ST_AsGDALRaster.html>>
>>>>>>>>> as well as the raster2pgsql commandline tool.
>>>>>>>>> *From:*Lukas Panhirsch via postgis-users <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>>
>>>>>>>>> *Sent:*Tuesday, April 8, 2025 9:28 AM
>>>>>>>>> *To:*postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>>>>>>>>> *Subject:*Why does the raster type not have send/receive defined?
>>>>>>>>> Hello,
>>>>>>>>> I haven't used this mailing list before and couldn't figure out how to
>>>>>>>>> search in the archives, so I apologize if this has been answered before.
>>>>>>>>> Is there any specific reason why the raster type does not have the
>>>>>>>>> send/receive functions in its SQL type definition?
>>>>>>>>> The geometry type has these defined as conversions to/from EWKB, which
>>>>>>>>> are equivalent to ST_AsEWKB/ST_GeomFromEWKB if I understand correctly.
>>>>>>>>> Equivalent (E?)WKB conversion functions exist for rasters in the form
>>>>>>>>> of (RT_)ST_AsBinary/ST_RastFromWKB, but have to be called explicitly.
>>>>>>>>> I would like to use PostgreSQL features like COPY ... WITH BINARY with
>>>>>>>>> rasters, but it seems this is preventing me from doing so.
>>>>>>>>> Sincerely,
>>>>>>>>> Lukas
