[a little bit OT] calculating X,Y from latitude and longitude
Kobben, Barend (UT-ITC)
b.j.kobben at utwente.nl
Tue Aug 19 01:29:14 PDT 2025
You can’t unless you know which X & Y you want/mean. It is NOT correct to say that y is latitude and x is longitude!! XY means you use a cartesian coordinate system (the map = flat rectangle) instead of lat & lon which are angles from the center of a spheroid or ellipsoid (the globe = a 3D object).
We call the transformation from 3D globe to flat map a projection. There are endless ways of projecting. Choose one of those projections and do the math and then you go from lat-lons to y-es and x-es...
For a nice overview of all this see e.g. https://kartoweb.itc.nl/geometrics
Yours,
Barend Köbben
Senior Lecturer/Researcher – ITC-GIP
Thesis Coordinator STAMP & M-CARTO (Joined Erasmus Mundus MSc in Cartography)
University Twente, PO Box 217, 7500 AE Enschede (The Netherlands)
+31-(0)53 4874 253 / room 1303 Langezijds (Hallenweg 8)
On 18/08/2025, 21:53, "Luca Bertoncello" <lucabert at lucabert.de> wrote:
Am 18.08.2025 um 17:34 schrieb Robert Hewlett:
> First step, make sure you are not crossing over.
> You say x y but latitude longitude is y x.
Yes, I know... y is latitude and x is longitude...
How can I calculate them?
Thanks
Luca Bertoncello
(lucabert at lucabert.de)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250819/c3eb07ef/attachment.htm>
