ogr2ogr with missing geometries crashes postgresql with segmentation fault
Paul Ramsey
pramsey at cleverelephant.ca
Mon Dec 15 09:15:22 PST 2025
I have started a ticket, and have a fix in hand.
https://trac.osgeo.org/postgis/ticket/6028
On Sat, Dec 13, 2025 at 6:28 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> First, thank you for a perfect minimal reproducer right up front. Very
> helpful and I have confirmed a crash here too. I haven’t put it into the
> debugger yet. Your empty polygon is pretty cool (as polygons tend to be)
> since it is not a classic “polygon with no rings” empty polygon, it is a
> “polygon with one ring that has no points” empty polygon.
> 01 // LITTLE ENDIAN.
> 03000020 // POLYGON, WITH SRID
> 97130000 // SRID 5015
> 01000000 // ONE RING
> 00000000 // ZERO POINTS
> Why that causes a crash in the index code (or perhaps the bounding box
> extraction code) is yet to be determined.
> Anyways, very exciting to have a crasher, quite a rare defect these days.
> ATB,
> P.
> On Dec 12, 2025, at 5:19 PM, Jorge Gustavo Rocha <jgr at di.uminho.pt> wrote:
> TL;DR
> A GIST index on a EMPTY POLYGON (encoded by GDAL) crashes postgresql with
> segmentation fault.
> drop table if exists fault;
> create table fault (fid integer, geom geometry(Polygon,5015));
> INSERT INTO fault (fid, geom) VALUES (1,
> '0103000020971300000100000000000000'::GEOMETRY);
> CREATE INDEX fault_geom_index ON fault USING GIST (geom);
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251215/4095546f/attachment.htm>
