ogr2ogr with missing geometries crashes postgresql with segmentation fault
Paul Ramsey
pramsey at cleverelephant.ca
Mon Dec 15 16:35:33 PST 2025
Should be fixed in all stable branches and going forward.
On Mon, Dec 15, 2025 at 9:15 AM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> I have started a ticket, and have a fix in hand.
> https://trac.osgeo.org/postgis/ticket/6028
> On Sat, Dec 13, 2025 at 6:28 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> First, thank you for a perfect minimal reproducer right up front. Very
>> helpful and I have confirmed a crash here too. I haven’t put it into the
>> debugger yet. Your empty polygon is pretty cool (as polygons tend to be)
>> since it is not a classic “polygon with no rings” empty polygon, it is a
>> “polygon with one ring that has no points” empty polygon.
>> 01 // LITTLE ENDIAN.
>> 03000020 // POLYGON, WITH SRID
>> 97130000 // SRID 5015
>> 01000000 // ONE RING
>> 00000000 // ZERO POINTS
>> Why that causes a crash in the index code (or perhaps the bounding box
>> extraction code) is yet to be determined.
>> Anyways, very exciting to have a crasher, quite a rare defect these days.
>> ATB,
>> P.
>> On Dec 12, 2025, at 5:19 PM, Jorge Gustavo Rocha <jgr at di.uminho.pt>
>> wrote:
>> TL;DR
>> A GIST index on a EMPTY POLYGON (encoded by GDAL) crashes postgresql with
>> segmentation fault.
>> drop table if exists fault;
>> create table fault (fid integer, geom geometry(Polygon,5015));
>> INSERT INTO fault (fid, geom) VALUES (1,
>> '0103000020971300000100000000000000'::GEOMETRY);
>> CREATE INDEX fault_geom_index ON fault USING GIST (geom);
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251215/fe8ae35b/attachment.htm>
