Error on raster2pgsq - rt_band_from_wkb: Premature end of WKB on band offline path reading.
Chater, ST, Mnr [schater@sun.ac.za] schater at sun.ac.za
Wed Feb 5 04:32:58 PST 2025
I am trying to ingest an out-DB raster into PostgreSQL 15 database using the raster2pgsql command. I have PostGIS 3.3.8 installed (recently upgraded from 3.2). This server is running Rocky Linux (will refer to this as server A). Please note this server is running a production application so I would prefer not to have to uninstall everything and restart from scratch.
This is the command I have used in the past and have been using now:
/usr/pgsql-15/bin/raster2pgsql -d -s 4326 -t auto -R -F -Y -e /home/<username>/Downloads/2016-01-01_40m_k30.tif public.test_raster_table | psql -U <postgres-user> -d <db-name>
After upgrading to PostGIS 3.2 I have been running into the following error when running my ingestion command:
[user at host Downloads]$ /usr/pgsql-15/bin/raster2pgsql ....
Processing 1/1: /home/demsa/Downloads/2016-01-01_40m_k30.tif
INFO: Using computed tile size: 256x256
DROP TABLE
CREATE TABLE
COPY 50
COPY 50
COPY 50
COPY 50
COPY 50
COPY 50
COPY 50
COPY 50
COPY 50
munmap_chunk(): invalid pointer
ERROR:  rt_band_from_wkb: Premature end of WKB on band offline path reading
CONTEXT:  COPY backfill_table_mean, line 42, column rast: "010000010043EEF8D9F5353A3F4075AD9570363ABF9A3CA74761E4334043AAD5064C5641C000000000000000000000000000..."
I have successfully ingested out-DB rasters to the same database in the past. In fact, the 2016-01-01_40m_k30.tif in the above command is one of the files that I have successfully ingested into the same database in the past.
Attemps to resolve:
  *   I have created a blank raster in QGIS (test.tif), which is quite small (6x4 pixels) and attempted to ingest this with the above command. The same error appears, which leads me to believe there is something wrong with the install of PostGIS/postgis_raster package that I have.
  *   I copied both rasters (2016-01-01_40m_k30.tif and test.tif) across to another linux server (server B) which is has PostGIS 3.3.4. Using this command: /usr/pgsql-14/bin/raster2pgsql -d -s 4326 -t auto -R -F -Y -e /home/<username>/Downloads/2016-01-01_40m_k30.tif public.test_raster_table | psql -p 5432 -U <postgres-user> -d <dbname> -h <server A IP> I was successfully able to ingest both rasters into the database on server A.
     *   This leads me to believe that there is something wrong with the PostGIS version that I am using and not with the rasters themselves.
  *   Tried various combinations of the raster2pgsql flags
Removed -t auto
free(): invalid pointer
Removed -e
COPY 50
COPY 50
COPY 50
ERROR: rt_raster_from_hexwkb: Raster HEXWKB input must have an even number of characters
CONTEXT: COPY backfill_table_mean, line 42, column rast: "010000010043EEF8D9F5353A3F4075AD9570363ABF9A3CA74761E4334043AAD5064C5641C00000..."
Removed -Y
ERROR: unterminated quoted string at or near "'2016-01-01_40m_k30."
LINE 1: ...362D30312D30315F34306D5F6B33302E74696600'::raster,'2016-01-0...
Removed -R
ERROR: rt_band_from_wkb: Premature end of WKB on band data reading (rt_wkb.c:201)
CONTEXT: COPY backfill_table_mean, line 49, column rast: "010000010043EEF8D9F5353A3F4075AD9570363ABF8835813D97FE3340FE80203F676341C000000000000000000000000000..."
The results of running gdalinfo (on separate windows PC) on both of the rasters I tried to ingest:
> gdalinfo 2016-01-01_40m_k30.tif
Driver: GTiff/GeoTIFF
Warning 1: PROJ: proj_create_from_database: C:\Program Files\PostgreSQL\14\share\contrib\postgis-3.3\proj\proj.db contains DATABASE.LAYOUT.VERSION.MINOR = 0 whereas a number >= 2 is expected. It comes from another PROJ installation.
Files: 2016-01-01_40m_k30.tif
Size is 7265, 8338
Coordinate System is:
GEOGCRS["WGS 84",
    DATUM["World Geodetic System 1984",
        ELLIPSOID["WGS 84",6378137,298.257223563,
            LENGTHUNIT["metre",1,
                ID["EPSG",9001]]]],
    PRIMEM["Greenwich",0,
        ANGLEUNIT["degree",0.0174532925199433,
            ID["EPSG",9122]]],
    CS[ellipsoidal,2],
        AXIS["latitude",north,
            ORDER[1],
                ID["EPSG",9122]]],
        AXIS["longitude",east,
            ORDER[2],
                ID["EPSG",9122]]]]
Data axis to CRS axis mapping: 2,1
Origin = (17.844391979228011,-31.500006410136233)
Pixel Size = (0.000399944803551,-0.000399973379606)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_SOFTWARE=GDAL 3.7.0e (3070046) (4.5.1;1700;3.0.0;2.0.7;;;;), PROJ 9.2.1 (EPSG.VERSION=v10.088;EPSG.DATE=2023-05-13;ESRI.VERSION=ArcGIS Pro 3.1;ESRI.DATE=2023-19-01;PROJ_DATA.VERSION=1.14;)
Image Structure Metadata:
  COMPRESSION=DEFLATE
  INTERLEAVE=BAND
  PREDICTOR=3
Corner Coordinates:
Upper Left  (  17.8443920, -31.5000064) ( 17d50'39.81"E, 31d30' 0.02"S)
Lower Left  (  17.8443920, -34.8349844) ( 17d50'39.81"E, 34d50' 5.94"S)
Upper Right (  20.7499910, -31.5000064) ( 20d44'59.97"E, 31d30' 0.02"S)
Lower Right (  20.7499910, -34.8349844) ( 20d44'59.97"E, 34d50' 5.94"S)
Center      (  19.2971915, -33.1674954) ( 19d17'49.89"E, 33d10' 2.98"S)
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
  Min=19.340 Max=27.754
  Minimum=19.340, Maximum=27.754, Mean=24.930, StdDev=1.194
  NoData Value=-9999
  Metadata:
    STATISTICS_APPROXIMATE=YES
    STATISTICS_MAXIMUM=27.753507614136
    STATISTICS_MEAN=24.93024257498
    STATISTICS_MINIMUM=19.340391159058
    STATISTICS_STDDEV=1.1943478187917
    STATISTICS_VALID_PERCENT=73.14
> gdalinfo test_grid.tif
Files: test_grid.tif
Size is 6, 4
GEOGCRS["WGS 84",
                ID["EPSG",9001]]]],
            ID["EPSG",9122]]],
    CS[ellipsoidal,2],
            ORDER[1],
                ID["EPSG",9122]]],
            ORDER[2],
                ID["EPSG",9122]]]]
Origin = (16.639998682000002,-31.334238383999999)
Pixel Size = (1.000000000000000,-1.000000000000001)
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  16.6399987, -31.3342384) ( 16d38'24.00"E, 31d20' 3.26"S)
Lower Left  (  16.6399987, -35.3342384) ( 16d38'24.00"E, 35d20' 3.26"S)
Upper Right (  22.6399987, -31.3342384) ( 22d38'24.00"E, 31d20' 3.26"S)
Lower Right (  22.6399987, -35.3342384) ( 22d38'24.00"E, 35d20' 3.26"S)
Center      (  19.6399987, -33.3342384) ( 19d38'24.00"E, 33d20' 3.26"S)
Band 1 Block=6x4 Type=Float32, ColorInterp=Gray
  NoData Value=0
The result of running sudo journalctl --no-pager | tail -n 30 immediately after raster2pgsql fails.
Feb 05 12:46:42 SUNGIS18 systemd[1]: Started Process Core Dump (PID 265814/UID 0).
Feb 05 12:46:42 SUNGIS18 systemd-coredump[265815]: Resource limits disable core dumping for process 265810 (raster2pgsql).
Feb 05 12:46:42 SUNGIS18 systemd-coredump[265815]: Process 265810 (raster2pgsql) of user 1000 dumped core.
Feb 05 12:46:42 SUNGIS18 systemd[1]: systemd-coredump at 133-265814-0.service<mailto:systemd-coredump at 133-265814-0.service>: Deactivated successfully.
Feb 05 12:46:42 SUNGIS18 systemd[1]: Started Process Core Dump (PID 265819/UID 0).
Feb 05 12:46:42 SUNGIS18 systemd-coredump[265820]: Resource limits disable core dumping for process 265813 (postmaster).
Feb 05 12:46:42 SUNGIS18 systemd-coredump[265820]: Process 265813 (postmaster) of user 26 dumped core.
Feb 05 12:46:42 SUNGIS18 systemd[1]: systemd-coredump at 134-265819-0.service<mailto:systemd-coredump at 134-265819-0.service>: Deactivated successfully.
Feb 05 12:46:44 SUNGIS18 sudo[265831]:    demsa : TTY=pts/2 ; PWD=/home/demsa/Downloads ; USER=root ; COMMAND=/bin/journalctl --no-pager
Feb 05 12:46:44 SUNGIS18 sudo[265831]: pam_unix(sudo:session): session opened for user root(uid=0) by demsa(uid=1000)
Any advice as to how I could investigate this further or resolve the issue would be much appreciated.
Many thanks
Sean Chater
The integrity and confidentiality of this email are governed by these terms. Disclaimer<https://www.sun.ac.za/emaildisclaimer/default.aspx>
Die integriteit en vertroulikheid van hierdie e-pos word deur die volgende bepalings bere?l. Vrywaringsklousule<https://www.sun.ac.za/emaildisclaimer/default.aspx>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250205/7417a780/attachment.htm>
