[postgis-users] [postgis-devel] Upgrade issues
James Sewell
james.sewell at jirotech.com
Wed Feb 19 18:46:08 PST 2025
It looks like this will be triggered for any PG13 -16 pg_upgrade with a
non 4326 geometry column.
I'm having trouble isolating where the error is coming from though ....
-J
On Thu, 6 Feb 2025 at 13:35, James Sewell <james.sewell at jirotech.com> wrote:
> The issue we ran into before when spatial_ref_sys was checked was when
>> there is say an index that uses a ST_Transform or a function used in a
>> table constraint that relies on spatial_ref_sys.
>> In those cases though I think the error was something like can’t find
>> srid 4326 etc. But the error you have below is that the table
>> public.spatial_ref_sys does not exist or for security reasons it’s not
>> accessible.
> If you look at the history in this message it’s the same error message
> from 2019 😀
>> Which version of PG13 are you upgrading from (include the minor as well)
>> and the PostGIS minor/micro e.g what this returns
>> SELECT postgis_full_version() || ‘ ‘ || version();
> Here you are, thanks for the help!
> POSTGIS="3.4.3 0" [EXTENSION] PGSQL="130" GEOS="3.7.2-CAPI-1.11.2
> b55d2125" SFCGAL="SFCGAL 1.4.1, CGAL 5.4.2, BOOST 1.66.0" PROJ="6.3.2"
> LIBXML="2.9.7" LIB
> JSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" TOPOLOGY
> PostgreSQL 13.18 (EnterpriseDB Advanced Server 13.18.24) on
> x86_64-pc-linux-gnu, compile
> d by gcc (GCC) 8.5.0 20210514 (Red Hat 8.5.0-22), 64-bit
> (1 row)
> *From:* James Sewell <james.sewell at jirotech.com>
>> *Sent:* Tuesday, February 4, 2025 4:15 PM
>> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>; Bradley
>> Latus <Bradley.Latus at jirotech.com>
>> *Subject:* Re: [postgis-users] [postgis-devel] Upgrade issues
>> This seems to be broken again for pg_upgrade?
>> Upgrading from PG 13 -> 16 and getting the same error as above.
>> ERROR: relation "public.spatial_ref_sys" does not exist
>> This was fixed here:
>> https://github.com/postgis/postgis/blob/master/postgis/gserialized_typmod.c#L150
>> Could it be the code block added above this since 2019? The issue was
>> PostGIS reading pg_spatial_ref_sys before it's populated in a pg_upgrade.
>> Cheers,
>> James
>> The contents of this email are confidential and may be subject to legal
>> or professional privilege and copyright. No representation is made that
>> this email is free of viruses or other defects. If you have received this
>> communication in error, you may not copy or distribute any part of it or
>> otherwise disclose its contents to anyone. Please advise the sender of your
>> incorrect receipt of this correspondence.
> James Sewell,
> *Chief Architect, Jirotech*
> Suite 46, Jones Bay Wharf, 26-32 Pirrama Road, Pyrmont NSW 2009
> *P *(+61) 2 8099 9000 <(+61)%202%208099%209000> *W* www.jirotech.com
> *F *(+61) 2 8099 9099 <(+61)%202%208099%209000>
The contents of this email are confidential and may be subject to legal or
professional privilege and copyright. No representation is made that this
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250220/7920b447/attachment.htm>
