[postgis-users] [postgis-devel] Upgrade issues
James Sewell james.sewell at jirotech.com
Wed Feb 5 16:35:22 PST 2025
> The issue we ran into before when spatial_ref_sys was checked was when
> there is say an index that uses a ST_Transform or a function used in a
> table constraint that relies on spatial_ref_sys.
> In those cases though I think the error was something like can’t find srid
> 4326  etc.  But the error you have below is that the table
> public.spatial_ref_sys does not exist or for security reasons it’s not
> accessible.
If you look at the history in this message it’s the same error message from
2019 😀
> Which version of PG13 are you upgrading from (include the minor as well)
> and the PostGIS minor/micro e.g what this returns
> SELECT postgis_full_version() || ‘ ‘ || version();
Here you are, thanks for the help!
 POSTGIS="3.4.3 0" [EXTENSION] PGSQL="130" GEOS="3.7.2-CAPI-1.11.2
b55d2125" SFCGAL="SFCGAL 1.4.1, CGAL 5.4.2, BOOST 1.66.0" PROJ="6.3.2"
LIBXML="2.9.7" LIB
JSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" TOPOLOGY
PostgreSQL 13.18 (EnterpriseDB Advanced Server 13.18.24) on
x86_64-pc-linux-gnu, compile
d by gcc (GCC) 8.5.0 20210514 (Red Hat 8.5.0-22), 64-bit
(1 row)
> *Sent:* Tuesday, February 4, 2025 4:15 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>; Bradley
> Latus <Bradley.Latus at jirotech.com>
> *Subject:* Re: [postgis-users] [postgis-devel] Upgrade issues
> This seems to be broken again for pg_upgrade?
> Upgrading from PG 13 -> 16 and getting the same error as above.
> ERROR:  relation "public.spatial_ref_sys" does not exist
> This was fixed here:
> https://github.com/postgis/postgis/blob/master/postgis/gserialized_typmod.c#L150
> Could it be the code block added above this since 2019? The issue was
> PostGIS reading pg_spatial_ref_sys before it's populated in a pg_upgrade.
> Cheers,
> James
> The contents of this email are confidential and may be subject to legal or
> professional privilege and copyright. No representation is made that this
> email is free of viruses or other defects. If you have received this
> communication in error, you may not copy or distribute any part of it or
> otherwise disclose its contents to anyone. Please advise the sender of your
> incorrect receipt of this correspondence.
James Sewell,
*Chief Architect, Jirotech*
Suite 46, Jones Bay Wharf, 26-32 Pirrama Road, Pyrmont NSW 2009
*P *(+61) 2 8099 9000 <(+61)%202%208099%209000>  *W* www.jirotech.com  *F *
(+61) 2 8099 9099 <(+61)%202%208099%209000>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250206/107024b5/attachment.htm>
