Error on raster2pgsq - rt_band_from_wkb: Premature end of WKB on band offline path reading.
Jorge Gustavo Rocha jgr at di.uminho.pt
Wed Feb 5 06:06:39 PST 2025
Hi Sean,
Make sure you don't have dangling gdal libraries around. Maybe after
upgrading, you still have old GDAL libraries.
Can you confirm that you have only one GDAL library?
Best regards,
Jorge
On 05/02/25 12:32, Chater, ST, Mnr [schater--- via postgis-users wrote:
> Hi,
> I am trying to ingest an out-DB raster into PostgreSQL 15 database
> using the raster2pgsql command. I have PostGIS 3.3.8 installed
> (recently upgraded from 3.2). This server is running Rocky Linux (will
> refer to this as server A). Please note this server is running a
> production application so I would prefer not to have to uninstall
> everything and restart from scratch.
> This is the command I have used in the past and have been using now:
> */usr/pgsql-15/bin/raster2pgsql -d -s 4326 -t auto -R -F -Y -e
> /home/<username>/Downloads/2016-01-01_40m_k30.tif
> public.test_raster_table | psql -U <postgres-user> -d <db-name>*
> After upgrading to PostGIS 3.2 I have been running into the following
> error when running my ingestion command:
> *[user at host Downloads]$ /usr/pgsql-15/bin/raster2pgsql ....*
> *Processing 1/1: /home/demsa/Downloads/2016-01-01_40m_k30.tif*
> *INFO: Using computed tile size: 256x256*
> *DROP TABLE*
> *CREATE TABLE*
> *COPY 50*
> *COPY 50*
> *COPY 50*
> *COPY 50*
> *COPY 50*
> *COPY 50*
> *COPY 50*
> *COPY 50*
> *COPY 50*
> *munmap_chunk(): invalid pointer*
> *ERROR:  rt_band_from_wkb: Premature end of WKB on band offline path
> reading*
> *CONTEXT:  COPY backfill_table_mean, line 42, column rast:
> "010000010043EEF8D9F5353A3F4075AD9570363ABF9A3CA74761E4334043AAD5064C5641C000000000000000000000000000..."*
> I have successfully ingested out-DB rasters to the same database in
> the past. In fact, the /2016-01-01_40m_k30.tif/ in the above command
> is one of the files that I have successfully ingested into the same
> database in the past.
> *_Attemps to resolve:_*
>   * I have created a blank raster in QGIS (/test.tif/), which is quite
>     small (6x4 pixels) and attempted to ingest this with the above
>     command. The same error appears, which leads me to believe there
>     is something wrong with the install of PostGIS/postgis_raster
>     package that I have.
>   * I copied both rasters (/2016-01-01_40m_k30.tif/ and /test.tif/)
>     across to another linux server (server B) which is has PostGIS
>     3.3.4. Using this command: /usr/pgsql-14/bin/raster2pgsql -d -s
>     public.test_raster_table | psql -p 5432 -U <postgres-user> -d
>     <dbname> -h <server A IP> I was successfully able to ingest both
>     rasters into the database on server A.
>       o This leads me to believe that there is something wrong with
>         the PostGIS version that I am using and not with the rasters
>         themselves.
>   * Tried various combinations of the raster2pgsql flags
> Removed |-t auto|
> free(): invalid pointer
> Removed |-e|
> COPY 50
> COPY 50
> COPY 50
> ERROR: rt_raster_from_hexwkb: Raster HEXWKB input must have an even
> number of characters
> "010000010043EEF8D9F5353A3F4075AD9570363ABF9A3CA74761E4334043AAD5064C5641C00000..."
> Removed |-Y|
> ERROR: unterminated quoted string at or near "'2016-01-01_40m_k30."
> LINE 1: ...362D30312D30315F34306D5F6B33302E74696600'::raster,'2016-01-0...
> Removed |-R|
> ERROR: rt_band_from_wkb: Premature end of WKB on band data reading
> (rt_wkb.c:201)
> CONTEXT: COPY backfill_table_mean, line 49, column rast:
> "010000010043EEF8D9F5353A3F4075AD9570363ABF8835813D97FE3340FE80203F676341C000000000000000000000000000..."
> *_The results of running gdalinfo (on separate windows PC) on both of
> the rasters I tried to ingest:_*
> *__*
> *> gdalinfo 2016-01-01_40m_k30.tif*
> Driver: GTiff/GeoTIFF
> Warning 1: PROJ: proj_create_from_database: C:\Program
> Files\PostgreSQL\14\share\contrib\postgis-3.3\proj\proj.db contains
> DATABASE.LAYOUT.VERSION.MINOR = 0 whereas a number >= 2 is expected.
> It comes from another PROJ installation.
> Files: 2016-01-01_40m_k30.tif
> Size is 7265, 8338
> Coordinate System is:
> GEOGCRS["WGS 84",
>     DATUM["World Geodetic System 1984",
>         ELLIPSOID["WGS 84",6378137,298.257223563,
>             LENGTHUNIT["metre",1,
>                 ID["EPSG",9001]]]],
>     PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433,
>             ID["EPSG",9122]]],
>     CS[ellipsoidal,2],
>         AXIS["latitude",north,
>             ORDER[1],
>                 ID["EPSG",9122]]],
>         AXIS["longitude",east,
>             ORDER[2],
>                 ID["EPSG",9122]]]]
> Data axis to CRS axis mapping: 2,1
> Origin = (17.844391979228011,-31.500006410136233)
> Pixel Size = (0.000399944803551,-0.000399973379606)
> Metadata:
>   AREA_OR_POINT=Area
>   TIFFTAG_SOFTWARE=GDAL 3.7.0e (3070046) (4.5.1;1700;3.0.0;2.0.7;;;;),
> PROJ 9.2.1
> (EPSG.VERSION=v10.088;EPSG.DATE=2023-05-13;ESRI.VERSION=ArcGIS Pro
> 3.1;ESRI.DATE=2023-19-01;PROJ_DATA.VERSION=1.14;)
> Image Structure Metadata:
>   COMPRESSION=DEFLATE
>   INTERLEAVE=BAND
>   PREDICTOR=3
> Corner Coordinates:
> Upper Left  (  17.8443920, -31.5000064) ( 17d50'39.81"E, 31d30' 0.02"S)
> Lower Left  (  17.8443920, -34.8349844) ( 17d50'39.81"E, 34d50' 5.94"S)
> Upper Right (  20.7499910, -31.5000064) ( 20d44'59.97"E, 31d30' 0.02"S)
> Lower Right (  20.7499910, -34.8349844) ( 20d44'59.97"E, 34d50' 5.94"S)
> Center      (  19.2971915, -33.1674954) ( 19d17'49.89"E, 33d10' 2.98"S)
> Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
>   Min=19.340 Max=27.754
>   Minimum=19.340, Maximum=27.754, Mean=24.930, StdDev=1.194
>   NoData Value=-9999
>   Metadata:
>     STATISTICS_APPROXIMATE=YES
>     STATISTICS_MAXIMUM=27.753507614136
>     STATISTICS_MEAN=24.93024257498
>     STATISTICS_MINIMUM=19.340391159058
>     STATISTICS_STDDEV=1.1943478187917
>     STATISTICS_VALID_PERCENT=73.14
> *> gdalinfo test_grid.tif*
> Files: test_grid.tif
> Size is 6, 4
> GEOGCRS["WGS 84",
>                 ID["EPSG",9001]]]],
>             ID["EPSG",9122]]],
>     CS[ellipsoidal,2],
>             ORDER[1],
>                 ID["EPSG",9122]]],
>             ORDER[2],
>                 ID["EPSG",9122]]]]
> Origin = (16.639998682000002,-31.334238383999999)
> Pixel Size = (1.000000000000000,-1.000000000000001)
> Metadata:
>   AREA_OR_POINT=Area
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  16.6399987, -31.3342384) ( 16d38'24.00"E, 31d20' 3.26"S)
> Lower Left  (  16.6399987, -35.3342384) ( 16d38'24.00"E, 35d20' 3.26"S)
> Upper Right (  22.6399987, -31.3342384) ( 22d38'24.00"E, 31d20' 3.26"S)
> Lower Right (  22.6399987, -35.3342384) ( 22d38'24.00"E, 35d20' 3.26"S)
> Center      (  19.6399987, -33.3342384) ( 19d38'24.00"E, 33d20' 3.26"S)
> Band 1 Block=6x4 Type=Float32, ColorInterp=Gray
>   NoData Value=0
> *_The result of running sudo journalctl --no-pager | tail -n
> 30 immediately after raster2pgsql fails._*
> Feb 05 12:46:42 SUNGIS18 systemd[1]: Started Process Core Dump (PID
> 265814/UID 0).
> Feb 05 12:46:42 SUNGIS18 systemd-coredump[265815]: Resource limits
> disable core dumping for process 265810 (raster2pgsql).
> Feb 05 12:46:42 SUNGIS18 systemd-coredump[265815]: Process 265810
> (raster2pgsql) of user 1000 dumped core.
> systemd-coredump at 133-265814-0.service: Deactivated successfully.
> 265819/UID 0).
> Feb 05 12:46:42 SUNGIS18 systemd-coredump[265820]: Resource limits
> disable core dumping for process 265813 (postmaster).
> Feb 05 12:46:42 SUNGIS18 systemd-coredump[265820]: Process 265813
> (postmaster) of user 26 dumped core.
> systemd-coredump at 134-265819-0.service: Deactivated successfully.
> Feb 05 12:46:44 SUNGIS18 sudo[265831]: demsa : TTY=pts/2 ;
> PWD=/home/demsa/Downloads ; USER=root ; COMMAND=/bin/journalctl --no-pager
> Feb 05 12:46:44 SUNGIS18 sudo[265831]: pam_unix(sudo:session): session
> opened for user root(uid=0) by demsa(uid=1000)
> Any advice as to how I could investigate this further or resolve the
> issue would be much appreciated.
> Many thanks
> Sean Chater
> The integrity and confidentiality of this email are governed by these
> terms. Disclaimer <https://www.sun.ac.za/emaildisclaimer/default.aspx>
> Die integriteit en vertroulikheid van hierdie e-pos word deur die
> volgende bepalings bereël. Vrywaringsklousule
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250205/3db72629/attachment.htm>
