Help creating "corridors"
Luca Bertoncello
lucabert at lucabert.de
Thu Feb 6 11:30:54 PST 2025
Am 06.02.2025 um 19:37 schrieb Regina Obe:
Hi Regina
> I don’t think OpenStreetMap data is going to help you with constructing
> flight corridors. As I recall these are 3 dimensional areal paths.
I do NOT need 3 dimensional areal path. 2 dimensional is enough, since
the altitude is not important for these data.
> You ultimately need 3 dimensional data – data that has altitude
> restrictions, and the city point in openstreetmap is pretty useless as I
> think that might just give you the centroid of a city which does not
> necessarily align with a corridor path. OpenStreetMap is more focused
> on visible things on the ground.
I do have the coordinates of cities and other elements (valley, lakes,
and so on).
I think, if I can create a path with these coordinates and add (let's
say) 30km left and right, I'll get the most airfield in these
"corridors", isn't it?
> I was thinking sources like https://openflights.org or
> https://opensky-network.org/ might have it but not seeing corridor data
> there
They do only display airplanes, and I don't need this.
> But if you do have reliable points, to Simon’s point, here is a pseudo
> coded example
Ok, this looks like interesting...
I have to make some experiments...
> To create a true corridor you probably should buffer the line string too
> and add an altitude something like below which would expand the
> linestring to 500 meter area and then maybe you add a upper altitude /
> lower altitude as separate columns for restrictions, but I think even
> the altitude restrictions change across the corridor so even this might
> not be enough to assume it’s constant across the corridor
As I said, I don't need the altitude, but buffering could be a good
idea, since the tables are huge...
Thanks a lot
Luca Bertoncello
(lucabert at lucabert.de)
