Help creating "corridors"
Roxanne Reid-Bennett
rox at tara-lu.com
Thu Feb 6 12:40:50 PST 2025
On 2/6/2025 11:30 AM, Luca Bertoncello wrote:
>> To create a true corridor you probably should buffer the line string too
>> and add an altitude something like below which would expand the
>> linestring to 500 meter area and then maybe you add a upper altitude /
>> lower altitude as separate columns for restrictions, but I think even
>> the altitude restrictions change across the corridor so even this might
>> not be enough to assume it’s constant across the corridor
> As I said, I don't need the altitude, but buffering could be a good
> idea, since the tables are huge...
Luca,
Buffering isn't unlikely to help performance while manipulating a large
collection of points. Which is my interpretation of your intent in the
statement above.
Nobody really asked you what you meant by "corridor". Were your looking
to display area (polygon) or path (linestring) information? Buffering
turns a point or linestring into a polygon, allowing you to identify an
"area".
You seem to have a grasp of how you want to acquire points for the end
points and "along" your corridors. I am going to point out that Regina
implied (but didn't state), that an "order" is required on your points
to get a sane linestring to represent traveling from point A to point B
along a collection of points. (Simon's reference also uses an "order",
just a different type)
But, if you won't have an "order" on your distinct points to help with
drawing a linestring from Point A to Point B, you can probably build a
polygon from the points. Buffering points and union'ing them to a
(multi)polygon might allow you to build your "corridors". Doing that
would best be done on a corridor by corridor basis (using some other
attribute on your points) because I suspect you have multiple corridors
going out from airports and "just" buffering "all" points will result in
nothing particularly useful.
Roxanne
