User-defined SRIDs are not working after Postgis 3.3.2 to 3.5.3 update
James Klassen
klassen.js at gmail.com
Fri Jul 25 06:43:47 PDT 2025
Did you run
SELECT postgis_extensions_upgrade();
https://postgis.net/workshops/postgis-intro/upgrades.html#upgrading-postgis
On Fri, Jul 25, 2025 at 08:18 Alexander Trufanov <trufanovan at gmail.com>
wrote:
> UPD. Just noticed that
> SELECT ST_Transform('SRID=4326;POINT(0 0)'::geometry, 2000)
> doesn't work either.
> So it's not about user defined srids. The error happens at any access to
> public.spatial_ref_sys
> пт, 25 июл. 2025 г. в 16:08, Alexander Trufanov <trufanovan at gmail.com>:
>> Hello,
>> I have a Debian Bookworm-based system with Postgresql 15 and PostGis
>> 3.3.2 on it.
>> It works well, but recently I was faced with a requirement to use
>> ST_Clip() function with touching argument support. Thus I need PostGis
>> 3.5.x+.
>> There was no PostGis newer than 3.3.2 in the official repos, but I
>> managed to installed it with
>> sudo apt install -y postgresql-common
>> sudo /usr/share/postgresql-common/pgdg/apt.postgresql.org.sh bookworm
>> sudo apt install postgis=3.5* postgresql-15-postgis-3=3.5*
>> postgresql-15-postgis-3-scripts=3.5*
>> Then I updated my Postgis extension.
>> And now I'm facing an unexpectable problem. All my stored procedures are
>> working fine unless they are trying to use user-defined SRIDs from the
>> public.spatial_ref_sys. If so, they fail with following error message:
>> "ERROR: Unable to determine 'postgis' install schema
>> SQL state: XX000"
>> For example, this works:
>> SELECT ST_Transform('SRID=4326;POINT(0 0)'::geometry, 4326)
>> and this is not:
>> SELECT ST_Transform('SRID=4326;POINT(0 0)'::geometry, 100100)
>> My 100100 srid record is:
>> select * from public.spatial_ref_sys where srid = 100100
>> 100100, '', 1, 'GEOGCS["WGS 84", DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0], UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4326"]]', '+proj=longlat +datum=WGS84 +no_defs'
>> I was trying to update this record in the table in case there is some
>> trigger that should register it in some new cache or config - but it does
>> not help.
>> Is there any cache or something else to clean in public.spatial_ref_sys
>> for postgis 4.5.3?
>> Maybe user-defined srids should now be registered in another way?
>> Also the error message "Unable to determine 'postgis' install schema "
>> is quite confusing.
>> With best regards,
>> Alexander Trufanov
> With best regards,
> Alexander Trufanov
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250725/d77a6a45/attachment.htm>
