Postgreql/postgis : Error No space left on device SQL state: 53100
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Tue Jun 24 03:11:37 PDT 2025
Hello,
I am not sure what you wanted to do, but the query you wrote runs union
pairwise between all objects of the first table and second table, creating
NxM objects each of which is a sum of two different polygons in the first
and second layer. It is entirely possible that this consumes all of your
disk drive and then frees it back up during crash handling. Please get
someone to write the query to correctly do what you meant to do instead.
On Tue, Jun 24, 2025 at 12:37 PM celati Laurent <laurent.celati at gmail.com>
wrote:
> <https://gis.stackexchange.com/posts/494155/timeline>
> Dear all,
> I want to compare a geoprocessing done in QGIS and PostGIS. It involves a
> union of two large polygonal vector layers.The processing in QGIS tooks 1.5
> hours on a well-equipped workstation (32 GB of RAM). I was never able to
> complete the processing on PostGIS.
> Here is the tested SQL query:
>> create table public.union as select st_union(ST_Forece2D(mos.geom),
>> ST_Forece2D(bd_topo_bat.geom)) from public.mos, public.bd_topo_bat
> Here is the error message:
>> ERROR: could not extend file "base/19370/76968.57" with FileFallocate():
>> No space left on device HINT: Check available disk space. ERROR: Could
>> not extend file "base/19370/76968.57" with FileFallocate(): No space left
> The error message is related to a problem with the temporary log file. In
> the postgresql.conf file, I edited the file by setting the value of
> log_temp_files = 10240. The default value was -1. I took this action based
> on this post:
> https://stackoverflow.com/questions/50833992/postgresql-no-space-left-on-device
> Thanks so much.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250624/192f707b/attachment.htm>
