Postgreql/postgis : Error No space left on device SQL state: 53100
celati Laurent
laurent.celati at gmail.com
Tue Jun 24 03:34:01 PDT 2025
Thanks so much for your reply. For information, i try to do with Postgis
the union Qgis Geoprocessing :
https://docs.qgis.org/3.40/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html#union
Le mar. 24 juin 2025 à 12:11, Darafei "Komяpa" Praliaskouski <me at komzpa.net>
a écrit :
> Hello,
> I am not sure what you wanted to do, but the query you wrote runs union
> pairwise between all objects of the first table and second table, creating
> NxM objects each of which is a sum of two different polygons in the first
> and second layer. It is entirely possible that this consumes all of your
> disk drive and then frees it back up during crash handling. Please get
> someone to write the query to correctly do what you meant to do instead.
> On Tue, Jun 24, 2025 at 12:37 PM celati Laurent <laurent.celati at gmail.com>
> wrote:
>> <https://gis.stackexchange.com/posts/494155/timeline>
>> Dear all,
>> I want to compare a geoprocessing done in QGIS and PostGIS. It involves a
>> union of two large polygonal vector layers.The processing in QGIS tooks 1.5
>> hours on a well-equipped workstation (32 GB of RAM). I was never able to
>> complete the processing on PostGIS.
>> Here is the tested SQL query:
>>> create table public.union as select st_union(ST_Forece2D(mos.geom),
>>> ST_Forece2D(bd_topo_bat.geom)) from public.mos, public.bd_topo_bat
>> Here is the error message:
>>> ERROR: could not extend file "base/19370/76968.57" with
>>> FileFallocate(): No space left on device HINT: Check available disk
>>> space. ERROR: Could not extend file "base/19370/76968.57" with
>>> FileFallocate(): No space left on device SQL state: 53100
>> The error message is related to a problem with the temporary log file. In
>> the postgresql.conf file, I edited the file by setting the value of
>> log_temp_files = 10240. The default value was -1. I took this action based
>> on this post:
>> https://stackoverflow.com/questions/50833992/postgresql-no-space-left-on-device
>> Thanks so much.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250624/6f58dfd8/attachment.htm>
